Hot Bodies TCX
#3287
which brand of diff oil do you guys use for your gear diffs??
#3291
With the stock shock towers, the shocks are extended pretty far to get the correct downtravel. In order to get the springs set with enough preload to maintain a proper ride height, the preload collars are way down in the range of the body. With the lowered towers, the preload does not need to be set in such a way. Its not a functional thing, just something I noticed that was kind of nice. The most important change with the shock towers is the piston position change In my opinion.
-Korey
-Korey
#3292
I've been running 46mm without issue - no binding at all...Korey gave an explanation of what the longer shafts gives you, feeling-wise, but I just don't have a set of 44mm shafts to compare which feel of the car I like better - so the 46mm stay in mine...
#3293
Thanks Korey for a great explanation.
In addition to that, i just wanted to let you know we are releasing those new parts below very soon.
#68758 ALUMINUM SERVO SPACER 1mm (2pcs)
#68759 UNIVERSAL AXLE PIN COVER (2pcs)
#68760 NARROW MAIN CHASSIS (2.5mm)
#68763 FRONT SHOCK TOWER (LOW MOUNT)
#68764 REAR SHOCK TOWER (LOW MOUNT)
#68765 SHOCK PISTON 3 HOLES (1.2mm/TEFLON/2pcs)
#68768 SHOCK PISTON 6 HOLES (1.1mm/TEFLON/2pcs)
#68769 SOLID AXLE LONG CUP (STEEL/2pcs)
#68712 UPPER DECK (2.5mm)
#68770 SOLID AXLE LONG CUP (POM/2pcs)
#68772 PIVOT BLOCK FR (+0.5 DEGREE)
#68773 PIVOT BLOCK FR (+1.0 DEGREE)
#68774 PIVOT BLOCK RF (+0.5 DEGREE)
#68775 PIVOT BLOCK RF (+1.0 DEGREE)
#68776 PIVOT BLOCK (3.5 DEGREES)
#68777 PIVOT BLOCK (4.0 DEGREES)
#68794 UNIVERSAL DRIVE SHAFT 46mm (STEEL/46mm/1pc)
#68796 FRONT SPINDLE/REAR HUB CARRIER SET
We are also working on some more stuffs to make the car even better. Stay tuned!
#3294
hi Korey,
i have a few questions regarding the tcx:
i tried the tamiya front hubs to get more steering and honestly the tamiya and yok hubs are used very often; my problem is, that the aluminium drive shaft locks /chatters at the end. which hubs do you use and should i try also the tamiya drive shafts to minimize the chattering?!
you wrote a lot about the right position of the piston in the shocks; how long is the overall length of your shocks?
please, can you also explain what happens, if you use wider front pivot blocks (1° or 1,5°) instead of the original one; also what is the effect of using a wider front block in ff.
thanks in advance
chris
thanks in advance
chris
#3295
http://www.hpiracing.com/graphics/in.../Pro4_pg32.jpg
it gives you an explanation of what changing the front toe-blocks does - its very basic and i'm sure there are other guys on here that can explain in greater detail, but I found this to be useful
In the front, the lower you go (ie, 2.0 -> 1.5 -> 1.0 -> 0) the more stability you get in the front...
Hope it helps
#3296
Well I should get my TCX later today after class. By tomorrow night it will likely be a TCX /417. If all goes well I have a 417 ver II diff on the way by noon today and in my hands tomorrow. Also what I am guessing are the correct parts to convert the drivetrain using Cyclone TC belts. Hopefully I will have a diff that doesn't leak and is concentric
#3297
#3298
8 turn
Does anyone remember the final gear ratio for an 8 turn brushed motor a starting point would be a great help
#3299
hi Korey,
thanks in advance
chris
thanks in advance
chris
I totally missed this post. Sorry it's taken me a while to notice it .
Overall length for stock shock towers is usually about 64.5mm. With the lowerered towers, I like 63.5 to 64.0mm. I know it may seem like a very small difference, but it does change how the car drives. I think it's important to measure your shocks . The car will generally feel a little more "stuck" with a slightly shorter shock. You can also tune the balance of the car slightly as well. Sometimes I run 63.5 in the front, and 64.0-64.5mm in the rear to get the rear end to rotate a little more.
I personally use Tamiya steering knuckles right now. I honestly don't see the chatter as a terrible thing. I usually try not to turn the wheel that much anyway. Something to think about is how differently the car reacts when it is unload (up in the air on a car stand) in comparison to how it is loaded (while on the ground driving). It usually won't chatter NEARLY as much on the track.
The FF suspension blocks control the amount of arm sweep in the front end. Arm sweep changes a few things in the geometry like ackerman, wheelbase, and inboard toe all at the same time. I've found the more arm sweep you run, the more steering the car will have right at the apex of the corner. Less arm sweep generally gives more steering into the corner, but less going through the middle and exit.
Hope that helps!
-Korey
