Tamiya TB-Evolution IV
#3316
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Originally Posted by terryh
I want to fit a ball diff to the front of my Evo IV MS but the rear one dosn't fit, does anyone know what I need to do to achieve this?
also a yoko SD diff bar the crown gear & 6mm diff balls fit also
i find the yoko thrust assy & diff screww alot better then the weedy tamiya one
#3318
Originally Posted by ljohnson
What do you mean by ""doesn't fit" ? I've run a rear diff in the front of my car, so it should fit. You will need to make sure it's shimmed right for the front so you don't destroy gears.
#3319
Originally Posted by MR JOLLY
terry the rear fit`s in the front !! no prob`s
#3320
Originally Posted by TryHard
Glad it helps terry
#3321
MS 4Sale
Anyone interested I have an "MS" 4sale $200 shipped lower 48.
roller chassis and oneway. excellent condition pics in the 4sale forum search MS
Pm if interested. No trades Please.
Thanks, Guys and Gals
#3323
my new Evo IV MS
well i finally have my Evo IV MS. ready to rumble. it will hit our club track for the first time this sunday!! i can't wait to give this thing a run!!!
Specs: ESC - Novak GTX
Motor - Tamiya Dyna Run 13x2
Batt - Nosram Big Mama 4200 Factory Team
Tyres - Tamiya Type A - Medim Insert
Body - Protoform Mazda 6 200mm
I have tidied up the wiring since the pics were taken. the battery connector now runs under the top deck and the motor leads are much shorter. it looks alot neater now
#3324
Looks very nice!
Good luck for your first outing with your car!
#3325
well...it ran like a dream!!! fist qualifier was more a shake down run. i took it easy. the car ran well. after that i just let loose. TQ'd and won the final. boy was i chaffed!!
1 question now. i will be running a 7x2 Team Brood V2 motor. what gearing would you guys suggest? Tamiya Type A tyres. below is a picture of the track that i race on.
#3326
i need help setting up my evo 4ms ive never raced it on asphalt i just need a few pointers i ran it today and no matter what i tried i couldnt stop the rear end from sending me into a full on drift i ended up turning the steering travel down low it helped a bit but it still is to hard to drive fast (running 27 sometimes 19)
#3327
what is the size of the screw that goes on the bottom side of the c hub into the hub ive lost both and i aint got a manual to see the sizes to order some more
#3328
#3329
#3330
What size pinion and spur gear would you guys recommend for my evo IV MS running a Novak GTB 4.5 looking at long runtimes and another setup for high speed runs
