Tamiya TB-Evolution IV
#3212
What drives me nuts is that this car never gets any props in and mags...I see the pro4, TC4...This car is way better than any of those...
#3213
Car is huge in Japan though where 23t is popular. R/C World magazine from Japan has done some articles on the car. You can tell a lot from the pics and setup sheets but it really helps to be able to read Japanese
#3214
Can anyone help me figure out what pinion to use? I'm planning to run my EVO IV with 19t motor at the Tamiya track and I was told to start with 32-33mm rollout if using 96t spur gear. I have no clue in calculating for pinion with rollout and spur.
#3215
#3216
Terrell, here is that setup. Just do the changes I suggested and go from there...
Foam tire/Carpet Setup for Stock...
Don't forget, the Rebound stroke is Droop that I measure with droop gauge. Front is measure from the bottom of grub screw hole on caster block. In the rear it's the bottom of the aluminum 0degree hub.
#3217
hey guys i just sold my 415 and bought a 2nd hand tb evo 4ms. It came in the mail a week or so ago and it was brand new it didnt have a scratch on it. i picked it up for $277aud and am using a tamiya tz 23t and all i can say is that this chassis and motor combo turns the car into an animal . just 1 question to ask. what do i need to do or buy so i can use my old shells that i used on my 415 so i can use them on the evo?
Cheers,
Pat
Cheers,
Pat
#3218
Cheers,
Pat
Cheers,
Pat
[email protected]
#3219
Cheers,
Pat
Cheers,
Pat
#3220
hi there, ive just made a jump from a TC3 to a evo 4ms fully hopped up i haven't got it yet but its paid for how easy is the car to set up im running rubbers on carpet and i could do with a few pointers as where to start also will associated springs work on the shocks or will i need to buy new tamiya ones cheers
#3221
Hi again Adam,
I'm not following you around but , the best springs for tamiya shocks are tamiya springs If you shoot me a mail I will give you a list of all places you can get them shipped in for next to nothing.
#3222
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
stalker (sean guy)
just what i`ve just picked up EVOiv
just fiddling with it
spring chart would help (anyone) ???
#3223
How you doing Colin,
Get back on your own link
Hope you and yours are well. I thought you were looking at the 415msx. As for spring charts , I will look out for one , if I can remember where I saw it.
I say its best to use tamiya spring as they are a much better fit around the collar and cheaper. I will be truthefull and say I dont feel there is a great deal of difference between the set of 4 which come on the card with "soft" "medium" "medium hard" and "hard" on the legs the springs are packaged on.
I have used other springs on the shocks but find to alter them drastically then just change the oil.
Where you racing yours Colin (carpet or tarmac)
#3224
is there racing down in cow land on feb 12th
i`m just borrowing other peeps cars (cheaper this way) then give them back when i`m fedup with it
carpet slicks
also got a surikin version coming aswell £120.00
waht is on this one compared to the other s?? apart from being red anodised instead of boring blue
carpet slicks
#3225
carpet slicks
carpet slicks
also spares in red version are bad.
this car is quite old now and the evo4 and evo4ms is an updated version with LWT suspension and 3 piece prop.
