Tamiya TB-Evolution IV >
Like Tree2Likes
Old 06-04-2005 | 07:33 AM
  #3001
razzo's Avatar
Originally Posted by Chrominator
Hey I was wondering if I could get some advise from you Tamiya guys ?
I'm running Tamiya shocks on my xxx-s, I'm using the gold ball studs that the shocks mount to, but the threads are a little short. a guy at my local track ''SRS'' gave me one that had long threads on it, but he didn't know the part #.
I went to the Tamiya web site and I could not find any thing. I tried a few local Hobby shops that sell Tamiya parts, no one seems to know what car uses that ball stud or that part #.
I see lundsford sells alot of different size ball studs but I don't know what size it is.
If any of you guys could help me with this I would really appreciate it.
Also I was wondering If any of You guys would know how many different size pistons, Tamiya makes for there shocks, and what would be the closest equivalent to losi pistons?
Do any other brand of pistons fit the Tamiya shocks?
I figured out that the Associated springs fit the Tamiya shocks.
Any and all help with these questions would be greatly appreciated.
Thanks Mike.
Go and ask Todd Hodge over at his thread. While back he posted Tamiya 2/3 hole piston to Losi equivalnt (when he ran Tamiya shocks on his XXX-S/Proto JRX-S) Also, I'm guessing he'll have the part # that will be correct for ball stud to get it to work on the Losi.
razzo is offline
Old 06-04-2005 | 08:36 AM
  #3002
fraz's Avatar
IIRC, the XXX-S has #56 and #54 pistons. These numbers correspond with an American Wire Gauge drill bit size. Go down to your local hardware stoe that has wire sized bits and try fitting the back side of the bit in the piston hole. As long as you have the right size and number of holes, the dampening should be the same with a given oil.
fraz is offline
Old 06-04-2005 | 06:28 PM
  #3003
Csaari77's Avatar
Does anyone know a store that I can find the flange tubes that go into the bottom of the caster blocks? My LHS hasn't had much luck getting things in from Tamiya and Speedtech is out. Please help!
Csaari77 is offline
Old 06-04-2005 | 10:16 PM
  #3004
Turbonium's Avatar
if you are talking about mounting TRF shocks to the shock tower, these are probably the easiest way:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSC7&P=7
that way, you can use as long a 3mm screw as you need... and at the bottom, i have seen a long grub screw used in the arm, with these nuts on it, kinda like an Xray lower.
Turbonium is offline
Old 06-04-2005 | 10:44 PM
  #3005
fraz's Avatar
No that is not what he is talking about. He is looking for the flange tubes that space the kingpin screw in the c-hub where it screws into the knuckle.
I found some other Tamiya ones in a pinch but they were a little longer. A few minutes with my Dremel and burning my fingers, they were the same length as the stock Evo ones. I do not recall what kit they came from becuase somebody handed them to me at SoCal but they look just like the originals with the exception of the length.
P.S. the next time they become available, buy a few. They are popular and sell out fast. Try http://www.victorracng.com and see if Victor has any. He has been able to get some other Tamiya stuff for me quickly that others could never get. Tell him I sent ya.
fraz is offline
Old 06-04-2005 | 10:45 PM
  #3006
fraz's Avatar
Default Green with envy
I was trippin' around Jason's Store and found this green conversion kit. Looks pretty sweet!!
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5975623134
fraz is offline
Old 06-04-2005 | 10:49 PM
  #3007
Turbonium's Avatar
sorry... i should have quoted the above. i was replying to the above post looking for the hardware to mount the TRF shocks on another chassis....
i do know what the flange tubes are... somewhere i have a whole bag full of 'em!
Old 06-05-2005 | 01:34 AM
  #3008
Thai3g_Eclipse's Avatar
Hey fellow EVO IV owners, was wondering if anyone can tell me what part tree(s) do I need to get a complete battery hold-down assembly. I'm missing the battery strap posts and the hold down strap itself. I don't have a manual so if someone can tell me it'd be great. Thanks.
Thai3g_Eclipse is offline
Old 06-05-2005 | 05:13 AM
  #3009
Turbonium's Avatar
well, looks like to get that, you need 2....
51102 B-tree has the strap, body posts, and front bumper....
50989 J tree has the end mounts, antenna holder...etc.
you might still need someting else, tho... the little steel posts that screw into the mounts...which are in screw bag B #9465635, or by themselves is #9805886.
hope that helps.
Old 06-05-2005 | 05:57 AM
  #3010
BrainTeased's Avatar
i used a tube from the servo kits works alright when your desperate.
BrainTeased is offline
Old 06-05-2005 | 06:04 AM
  #3011
f1larry's Avatar
is this what you are looking for http://www.speedtechrc.com/store/ebp...id=245&id=1641
or this http://www.speedtechrc.com/store/ebp...id=273&id=1813
either way try ordering them from Rainbowten in Japan http://www.rainbowten.co.jp/english/index.html , thats where I have order them from when Speedtech is out of them
f1larry is offline
Old 06-05-2005 | 11:19 AM
  #3012
hope that helps.
Perfect. Thanks!
Old 06-06-2005 | 10:29 AM
  #3013
Csaari77's Avatar
Thanks for the tip on victorracing.com Fraz. He had the parts in stock, so I got a couple of them. I really was not looking forward to paying all the extra charges from rainbow ten.
Csaari77 is offline
Old 06-06-2005 | 11:04 AM
  #3014
Default EVO4 Limited Edition Parts for Sale!
EVO4 Centre Shaft in Green (Limited Edition)
TRF Green Shock Parts (Limited Edition)
EVO4 Aluminium Parts in Green (Limited Edition)
EVO4 Gear case (avaliable in Clear and Smoke)
All for USD$200. Exclude shipping.
PM me if interested.
Attached Thumbnails Tamiya TB-Evolution IV-evo4-green-centre-shaft.jpg   Tamiya TB-Evolution IV-green-trf-shocks.jpg   Tamiya TB-Evolution IV-evo4-green-parts-set.jpg   Tamiya TB-Evolution IV-evo4-gear-case-clear-.jpg   Tamiya TB-Evolution IV-evo4-gear-case-smoke-.jpg
Ooooh! is offline
Old 06-06-2005 | 12:01 PM
  #3015
V12's Avatar
V12
And the damper cylinders in orange-gold.
Reminds me on the original shocks of the very first Associated buggy with the goldtube chassis.
Attached Thumbnails Tamiya TB-Evolution IV-trf-damper-cylinders-orange-gold.jpg
V12 is offline
