-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Still Bill 04-03-2005 05:34 PM
Re: 12L4
Originally posted by fire929
12L4 guys any way to take side to side slop from the front wheels of my 12L4.:confused:
1) Motor shims
Or
2) Get optional threaded front axles (also eliminates the e-chips)
ALBERTO 04-03-2005 05:39 PM
Originally posted by serpentracer1
On the Silva T-plate what you can do is cut the frt side of a .063 Tbar and use it in place of the plastic ones you can recess the screws in the bottom just be careful and it works fine and you'll never have to replace it unless you hit hard going straight.
I have seen a Silva T bar break He was running either an 8 or 9 turn and got a glitch and went straight into the wall almost under full power.
that is the best idea i have ever heard almost sounds too good to be true hahahahahahaha... SERPENTRACER1 YOU DA MAN....... Big thanks buddy
fire929 04-03-2005 05:39 PM
Part #
Any Part number or company that makes either one
ALBERTO 04-03-2005 05:43 PM
Re: Part #
here ya go
Switch Blade 04-03-2005 05:43 PM
Re: Part #
Lunsford makes threaded front axels. Sorry, i dont have a part #
Hyperform Racing 04-03-2005 05:48 PM
Re: 12L4
are you using the e-clip setup? if so you can shim it or you can get threaded axles and tighten the nut snug but not so snug as to hinder wheel spin.
Hyperform Racing 04-03-2005 05:49 PM
doh, you vguys beat me to it.
Still Bill 04-03-2005 05:52 PM
You should see our cars...he, he...
ALBERTO 04-03-2005 06:12 PM
my cable modem is like my l4 lightning fast :lol: :lol: :lol: :lol: :lol:
dakrat 04-03-2005 08:25 PM
Re: 12L4
add more shims on the king pin. i throw some thicker teflon shims in the mix.
dan-o 04-04-2005 06:49 AM
hey all can I put the carpet knife chassis on my L3???
I Like that layout better than the L3/4 layout. Thanks
Merciless 04-04-2005 10:48 AM
NO :weird:
completely different idea's on how to get the cars to work,
You'd so many parts it's just not worth it, sorry dude
odpurple 04-04-2005 11:32 AM
dan-o
You can't replace the chassis only. You can convert the car to a Carpet knife with CRC's conversion kit, part# 1305 for $130.
You could also convert to a SpeedMerchant Rev4 (a similar car) with their conversion, part #1407 for $125.
dan-o 04-04-2005 12:02 PM
Thanks for the quick replies.... Can't wait to fill the 1/12th scale void it has been years and 2000 mah ago..... if you know what i mean... it was all throttle control or you dump!!!
mudpuppy 04-04-2005 05:33 PM
If running an L4 with a stock motor (or maybe a 19 turn), what amperage should I charge a 4-cell GP3300 pack at?
