-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
vtl1180ny 02-05-2005 01:34 PM
I don't run one, I have a CK but it looks like a nice car and they seem to perform well.... If I was in the market for a T bar car I'd probably pick one up....
G Mills 02-05-2005 01:58 PM
Originally posted by dakrat
anyone runnnig the new crc t fource? what do u like and what u do not like about the kit? picking one up soon
I just got one a couple weeks ago. I've practiced with it a couple times and plan to race it tomorrow. It is similar to the AE 12L4 but with all the hopups. Right out of the box it was 2 tenths quicker than my L4. I'm very pleased with it. Plus it looks really cool with all the red parts.
nmt6789 02-05-2005 04:04 PM
Does anyone know how to set the tweak on an L4? I Dont have a tweak station or anything so are there any old skool methods?
Still Bill 02-05-2005 04:25 PM
Use one quarter (25 cent piece) on the top of each front wheel placed slightly forward of the top. Lift the front center (should be marked) of the chassis with a knife blade and see which coin drops first (right or left). That side is raising first and will be the one that you want to screw in (clockwise) on the adjustment screw. BUT, you also need to first back off (counter-clockwise) the adjustment screw on the opposite side so you don't overtighten the t-bar with the screws. Make little adjustments like 1/8 of a rotation on both sides at the max and keep checking the tweak with the coins over and over again.
nmt6789 02-05-2005 04:26 PM
How can I tell when the tweak is perfect?
odpurple 02-05-2005 04:31 PM
Pretty expensive alignment, Bill...I use nickels. And you should settle the chassis by tapping on the upper shock mount and/or the antenna before lifting the front.:D
odpurple 02-05-2005 04:33 PM
when the coins fall at exactly the same time.
Still Bill 02-05-2005 05:14 PM
od,
I agree about using nickels; but, I usually have two quarters in my pocket more often than two nickels. Besides, I get to put them back in my pocket when I'm done.
Just got back from Scotland; so, I can use penny/pence coins now. A UK penny makes a nickel look pretty expensive...he, he...
Still Bill 02-05-2005 05:16 PM
No such thing as exactly...but really, really close to the same time...he, he...
lespaul 02-05-2005 05:29 PM
auto breaking
new to 1/12 are you guys using auto breaking at all or free wheeling into turns, when I'am not hit the walls to break haha, I woundered if I should have some break dialed in.
dakrat 02-05-2005 05:45 PM
Re: auto breaking
depends on your driving style, some guys at our track uses drag brake at neutral some uses neutral brake. i free wheel
lespaul 02-05-2005 06:10 PM
breaking
whats drag break, is that when I break my t bar and the car's rear drags down the track!!
nmt6789 02-05-2005 06:20 PM
Drag break is when you release the throttle trigger and it automatically breaks. So when you go into the neutral position, it will break. It has nothing to do with your t-bar...
lespaul 02-05-2005 06:39 PM
haha cool thanks for the tip will try that at the track!!!
Still Bill 02-05-2005 06:41 PM
For stock motor racing on carpet with a Quantum Comp 2 in my 12L4, I use 5-0-0 settings on the ESC for punch/initial brake/automatic brake.
