Like Tree2991Likes
1/12 forum
Old 01-30-2005 | 04:58 PM
  #10621
vtl1180ny's Avatar
Originally posted by Chad_R40
Oh ok. Im goign to look for IRS website right now.
oh yeah.... hust to add my Threaded front axel snapped too.. like it was weak metal... anyone have this problem.
Which car??? I snapped the stock threaded that came with my CRC... Put the Lunsford Titanium and no more problems... Although I have a spare set just in case... the crappy thing is I had to chuck the nuckle cause I couldn't get the rest of the axel out....
vtl1180ny is offline
Old 01-30-2005 | 05:03 PM
  #10622
Tim Stamper's Avatar
Chad,
I have a few extra IRS shocks. Just let me know and I can get one to ya for 10 bucks complete. I have 3 silver ones that I am not currently using that were just re-built.
I will be going to RcScrewZ tuesday to drop some stuff off. I will have one with me just in case you might be able come by and want one.
Tim
Tim Stamper is offline
Old 01-30-2005 | 05:27 PM
  #10623
Oh hey Tim....You found me in the right place Sure i'll pick up one of those shocks off you, and you would not happen to have any front threaded axels would you? oh yeah i'll be at Screwz around 6:30 -7:00pm Tues..Damn night school...:-/
Chad_R40 is offline
Old 01-30-2005 | 06:42 PM
  #10624
crimson eagle's Avatar
Hi All,
AdrianM said earlier to run front turnbuckles in the lower servo holes (and Adrian please feel free to answer this if you see it). This give a lot of Ackerman, the inside wheel really cranks over. Does this have a detrimental effect on handling (steering)? Please explain how. I understand that the wheel need to turn different amount to track the actual direction of the wheel, I'd like to understand the effect on handling.
Thanks all.
Chris.
crimson eagle is offline
Old 01-30-2005 | 07:27 PM
  #10625
JohnB's Avatar
Default Ackerman
Here is about the best description of Ackerman I've seen:
http://users.pandora.be/elvo/c3/index.htm
Go to the "Alignments" section.
I run holes furthest down, as Adrian describes, when running the servo flat. Don't worry to much about Ackerman. Just shim the outter ball studs and get rid of the bump steer.
take care
john
JohnB is offline
Old 01-30-2005 | 07:52 PM
  #10626
Switch Blade's Avatar
Thanks for posting a link to that site JohnB. There is so much information that i'll have to spend a day or two wrighting down notes and stuff.
Switch Blade is offline
Old 01-30-2005 | 08:23 PM
  #10627
Default axles
vtl1180ny - CRC has new steel axles now. We have just received them. With still little testing, we havent broken one yet. however they are definately way stronger, and have a nice black finish.
Also look for a new improved center shock to hit the market.
Dayger is offline
Old 01-30-2005 | 09:21 PM
  #10628
Thanks Johnb,
Has anyone tried different Ackerman angles on the track with a 12th? If so what happened? I like the idea of reducing Bump steer (but I'd like to know how that affects handling too).
Chris.
Old 01-30-2005 | 11:43 PM
  #10629
ghoppa's Avatar
Default discharging...
Hey Guys,
new to 12th scale and I will be giving it a try in the next couple of weeks.....
question: I have had some battery packs and I need to cycle them before I loose them, but with my 6cell pack I use my integy 30amp discharger, but what you you all use for 4cell packs????
"Is it safe to use my Integy 30amp discharger????"
I need some experienced advice, please advise (a rookie....)
ghoppa is offline
Old 01-31-2005 | 12:40 AM
  #10630
Merciless's Avatar
With the 3.2r it's the anodising on the shock body causeing the problem !!
Just change that for an ass. std silver one and everything will be fixed
Merciless is offline
Old 01-31-2005 | 05:50 AM
  #10631
sg1's Avatar
sg1
Default CRC center shock
Dayger...
What will be changed on the center shock??
Wayne
sg1 is offline
Old 01-31-2005 | 08:26 AM
  #10632
Default Shock
Hey Wayne...
You won't have to use that white star piece to hold the shock together anymore. There's going to be a threaded bottom, with a cap.
Dayger is offline
Old 01-31-2005 | 08:35 AM
  #10633
WVRACER's Avatar
speaking of center shocks has anyone can up with a way to easly get it off to change batteries.
on my l4 i have to pop the shock every time i change batts
any suggestions
Rob
WVRACER is offline
Old 01-31-2005 | 08:45 AM
  #10634
vtl1180ny's Avatar
I don't understand why you'd have to remove the shock at all to change batteries.....
Old 01-31-2005 | 08:57 AM
  #10635
theisgroup's Avatar
i am using an xray lower shock mount on the antenna side. you do have to shave a little off the ball end, but it works great. uses a 3mm hex to take the shock off.
any suggestions
Rob
theisgroup is offline
