Originally posted by cyrrus Fatdoggy thanks for the info. what kind of motor spray do you recommend |
Man...I'm really looking forward to racing 1/12th as touring has gotten a bit insane lately.
Reading this thread reminds me that I still have alot of new stuff to learn. Thanks for the tip Fatdoggy! :) |
Ran 12'th mod last night at SoCal. Was a BLAST - finally, the car ran great. Didn't have a lot of speed, but was able to put down decent laps.
Had a new servo (borrowed a KO digital) that was supposed to be the same as the 9602 that I've been using - but it felt WAY faster - had to adjust my hand but was FUN. Qual'd 2nd, but in the main, the top motor mount screw came loose so, while I didn't screw up my spur gear (somehow. . .) I didn't finish. We're really gonna try and get the class going at SoCal. . . :D |
What do you like, dislike and what would you change about your 1/12 car?
Thanks AdrianM lazyboy and wes for all the help. Ive noticed that it is very hard to install and remove my rear ride height adjusters, and the bearings inside the ride height adjusters. Should I remove some of the material so that they slide in and do not need a lot of force to install?
you shoudl want them to fit in their snug you dont want them moving aroudn jsut make sure your bearings are free thats all you should need to worry about but make sure the burrs on them are removed that can give you a little trouble
Hey guys, just got back from practice and my shock keeps like poping out.. aka the piston pops out with all the washers and red seal and all the fluid goes on the battery:-/. i dont know what the cause is... and i notice Hara was using a touring car shock on his car and i was wondering what you all think of using a touring car shock instead of the mini shock..... for me it would be added sucurity it seems.
Any help... |
you need a shock rebuild kit the associated shocks tend to do that
Chad - Each time you rebuild the micro shocks you must replace the star clips.
Switch - Irs has some new ride height adjusters out. They are awsome and for $10 you can't go wrong. Each pair drops 1/2mm so you can always get the perfect ride height. They slide right in place and don't bind. Soviet - Good to see your back on rctech. |
Chad if you go to the IRS website Silva makes a shock for the 12th scale that screws(top of cap) on like a touring car shock or offroad shock
Originally posted by Chad_R40 Hey guys, just got back from practice and my shock keeps like poping out.. aka the piston pops out with all the washers and red seal and all the fluid goes on the battery:-/. i dont know what the cause is... and i notice Hara was using a touring car shock on his car and i was wondering what you all think of using a touring car shock instead of the mini shock..... for me it would be added sucurity it seems. Any help... mike |
Oh ok. Im goign to look for IRS website right now.
oh yeah.... hust to add my Threaded front axel snapped too.. like it was weak metal... anyone have this problem. |
Originally posted by fatdoggy Chad - Each time you rebuild the micro shocks you must replace the star clips. Switch - Irs has some new ride height adjusters out. They are awsome and for $10 you can't go wrong. Each pair drops 1/2mm so you can always get the perfect ride height. They slide right in place and don't bind. Soviet - Good to see your back on rctech. |
Any of you guys know what kid of shock Hara was using on his Hammer???
Originally posted by Chad_R40 Any of you guys know what kid of shock Hara was using on his Hammer??? looks like a regular 10th scale shocks to me. |
| All times are GMT -7. It is currently 03:37 AM. |
