Old 12 th scale bodies
I found some cool but old GTP and car bodies for 12th scale. The Chevy GTP body looks killer than the others. You think old school is still good enough to compete with the newer bodies out there? Click here.
LRP Quantum Comp 2 ESC programming
For 1/12th scale stock at Stockton, I was using the 3-0-0 programming settings on my QC2 ESC; but, recently tried 5-3-3 settings with questionable results. Extra punch was welcome; however, I was losing too much speed while in the turns. Any comments from the 'peanut gallery'?
New to this
Im new to this and need some basic setup advice
So now I have the my L4 setup as per the manual but im wondering what roulout I should am for when gearing the car. I will start out running a 10x2, using 48pitch gears. other recomendations are welcome Car configuration LRP QC2 ESC Sanwa Reciever Hitec MG Servo Running on asphalt only Maybe you guys can recommend a good website with lots of helpful links and setup tips ? Thanks for the help guys. |
Bill You let off in stock?:lol: :lol: :lol: :lol: :lol: :lol: :lol:
hi all,
i am new to 1/12 and have no idea. I brought the whole Parma series of tires cos there are less choices so there is less confusion...lol can anyone suggest what brand of tires are actually better..if at all. Also...what servos do you pros use for 1/12. I cannot find any KO analog mini servos...so got a cheapy Hitec HS225MGBB...the specs are ok but is it actually good for racing? Cheers |
Originally posted by AARON YOUNG You let off in stock?:lol: :lol: :lol: :lol: :lol: :lol: :lol: OK...back to some constuctive comments...:lol: :lol: :lol: |
its amazing how trends go.
Everyone I race with is now doing 12th scale. Well time to drop more cash in the career. And yes i call it a career, cause who sends this much on a hobby.;) |
thanks for the detailed information...lol
Originally posted by JohnMatrix its amazing how trends go. Everyone I race with is now doing 12th scale. Well time to drop more cash in the career. And yes i call it a career, cause who sends this much on a hobby.;) Yup I'm joining the bandwagon. This class rocks! More racing and less maintenance. You have to worry about setup, diffs, and motor. |
12L4 Questions
Hope one of you guys can help. I have an L4 and it's inconsistent. In one of my qualifiers the car was great. In the main, if I made a hard left or right the car's rear end just swung aroung for no reason. The funny part is that I did not change the setup from my qualifier to the main. Any ideas? The car was fine as far as tweak, ride height and tires. I just can't figure it out.
L3-L4
Got a question.Am converting my L3 front end over to the L4 one.The arm mounts are 0,5,and10 degree.Which is the stock/starting one to use?Had a quick look at someone's L4 and I could see they were not using the 0 degree ones,and he said it was setup as per the manual.Also,does the manual place the washers,one front,one rear to start?Thanks,Mario.
Re: L3-L4
Originally posted by lotus1 Got a question.Am converting my L3 front end over to the L4 one.The arm mounts are 0,5,and10 degree.Which is the stock/starting one to use?Had a quick look at someone's L4 and I could see they were not using the 0 degree ones,and he said it was setup as per the manual.Also,does the manual place the washers,one front,one rear to start?Thanks,Mario. take care john |
JohnB,Thanks.Any idea's about the 5 degree blocks?Are they an inbetween compromise between the 0 and 10 degree?or do they have different characteristics?Thanks,Mario.
Re: LRP Quantum Comp 2 ESC programming
Originally posted by JRX-S Bill For 1/12th scale stock at Stockton, I was using the 3-0-0 programming settings on my QC2 ESC; but, recently tried 5-3-3 settings with questionable results. Extra punch was welcome; however, I was losing too much speed while in the turns. Any comments from the 'peanut gallery'? Some guys put some pre-throttle into their speedo settings so the car rolls when the throttle is on neutral. You do this by settings in your transmitter, not on the speedo. Good luck. |
Re: 12L4 Questions
Originally posted by savio7 Hope one of you guys can help. I have an L4 and it's inconsistent. In one of my qualifiers the car was great. In the main, if I made a hard left or right the car's rear end just swung aroung for no reason. The funny part is that I did not change the setup from my qualifier to the main. Any ideas? The car was fine as far as tweak, ride height and tires. I just can't figure it out. What compound tires are you using? |
| All times are GMT -7. It is currently 06:18 PM. |
