Buds used to make a pivot ball tool to remove the balls.
I think IRS and Niftech both make brass balls for the front end and for the T-Bar. The latest batches from Associated fit fine, the ones last year were Junk. |
Originally posted by rayhuang unregistered-the receiver pack is installed. I charged it first time at 1 amp. Whats the max and what the recommended charge rate and peak detect on the 70maH Thanks, Ray Ray - I assume you are referring to a pack with a 70mah capacity. The best charging rate in always 1/10 the capacity, or in this case 7 mah. However, that charge rate usually ends up taking about 12 hours to complete the charge, unacceptable. So, push it up a little to around 15 mah. And just so you know, the lowest charge rate on the CE Turbo35 Stealth is 15 mah. I usually put the peak detect at .02 for these cells unless they false peak a lot. Then I bump it up till it doesn't false peak. I hope that helps. See you tomorrow. |
Originally posted by Unregistered Buds used to make a pivot ball tool to remove the balls. I think IRS and Niftech both make brass balls for the front end and for the T-Bar. The latest batches from Associated fit fine, the ones last year were Junk. The tool I use is from RaceTech. The bad news is that they are out of business. About the metal pivot balls from IRS. They are aluminum that has been hard anodized with a telon impegnation type coating. You might notice a little flash on the ID, but it goes away with a little running, or you can knock it off with a hobby knife. |
Originally posted by JBennett Do any of yall know where I can get a 1/12th scale oval car? |
Originally posted by Unregistered I would only charge them at .5 amps max with a .01 or .02 drop back. I've charged them at .7 amps with a .03 drop back but I get them for free... I'll see ya at Halo tomorrow... Sorry I stepped on your post as I was drafting mine at the same time. Say hello when you arrive tomorrow. |
Anyone have a L4 they are looking to get rid of?
Re: Re: Shock issues
Originally posted by Weschester Here's some good info. It's on the CRC web site. http://www.teamcrc.com/crc/modules.p...ewtopic&t=1086 I appreciate it and it looks as though I am NOT the only person having these issues with CRC shocks. Mike |
Originally posted by v0rtex Just dragging up my post; I didnt get any replies :) |
Re: Re: Re: Shock issues
Originally posted by Michal101 Wes, I appreciate it and it looks as though I am NOT the only person having these issues with CRC shocks. Mike |
Silva shock is the only way to go....
Every thing I have that used micro shocks now has a Silva on it.... AE should include it in the kits..... fatdoggy: I read that site all the time... It has some great info.... |
Originally posted by JBennett Do any of yall know where I can get a 1/12th scale oval car? Jake's Performance Hobbies 707-586-3375 www.jphracing.com |
Anyone who runs a speedmerchant?
Does the pivot balls fit associated front end?:o
1/12
What's better for 19T and carpet.....t-plate or pivot[hidge?]...anyone ever seen full floating or not attached in this manor???
Originally posted by Michal101 Wes, I appreciate it and it looks as though I am NOT the only person having these issues with CRC shocks. Mike The trick is so make sure that your shock and car are in sync. When the car is in it's ready to race state, meaning batteries and motor in car, and the droop of the rear pod and the chassis ground clearance is correct, the shock piston should never, ever bottom out or hit the top of the shock when the motor pod moves forward and or aft. You can check this by placing the car, ready to run, on a flat surface and press down on the antenna. The piston should not bottom out inside of the shock. Next pick up the car and pull down on the back of the motor pod. Again, the piston should not hit the top of the shock. Getting the static length of the shock is tricky but once set right, your car will work much better and you will stop blowing the shock apart. You set the static length of the shock by screwing the ball cups in or out. Sometimes you may have to shorten the ball cups to get the correct static shock length. |
| All times are GMT -7. It is currently 12:02 AM. |
