-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Still Bill 11-24-2004 06:44 AM
Originally posted by RC12L3a
a little comparation:
Car1:
Sanwa 141 Servo
Sanwa fm receiver 2 channel
GM v12 old version speedo
Yokomo 9t machine wound
GP3300 unmatched
Car2:
Futaba top liner servo
Lrp micro receiver
LRP Q2 speedo
Reedy 9t hand wound
GP3300 matched
what do you think about the differences? in terms of costs and performance
Budget vs. Performance. I would take performance every time.
Depending on the competition where you race, Budget only gets you into the entry level of the 1/12th Mod class. Otherwise, Performance gives you a chance to win against other similarly equipped cars.
Initially, the electronics (servo, receiver and speedo) are the more important elements because the motor and batteries are disposables.
Of course, if you can win with Budget, you may be a darn good driver in comparison to your competition.
tfrahm 11-24-2004 07:17 AM
Track specific tire question...?
Our local carpet track is using carpet that is NOT "ozite" -- it is more of an "office"/"indoor-outdoor" carpet... It works OK, etc. and is "fuzz" free, etc. which is nice -- the problem is that it is ABRASIVE and that it is a bit lower in traction. This combination is very hard on tires -- especially REAR tires...
I am currently running the standard GRAY rear, PURPLE front combination. The front tire wear is not great, but still acceptable. The rear tires are just wearing WAY too fast! I have to make gearing changes during the day to keep the rollout right!
What 'dot' will give me a bit more traction on the rear, with longer tire life? I know those two things tend to work in opposite directions, but with all the standard/exotic/natural compounds out there, I have to believe there is a better foam than 'Gray'...?
Would 'PINK' work? Would 'MAGENTA' be too firm (not enough "bite")? (JACO? CRC? TRC?)
B-B 11-24-2004 08:06 AM
JRX-S Bill; Hi Bill could you post your setup you use for Stockton? Did you race at Gilroy last Fri, and if you did what changes did you make? Iam having a little trouble getting my 12L3 setup, tire dia. springs, ride height. Thanx in advance hope you can make it to Gilroy this Fri. Big Bill
Tony Szep 11-24-2004 09:10 AM
Originally posted by mr. losi
tony, this is what josh told me to start with for stock
outer hole on the plate, stock caster, 2 deg of camber, i have the thick tbar, and losi hydr fluid in the tubes, the shock is 25 wt with the green spring, ft ride height 3.0, rear 3.5 at teh motor...(i set mine to 4 at the rear pod...) i too will be running mine for the first time sat.....it is a really nice car.....the onlywork i had to do was on the kingpins.....
Thanks Mr. Losi
fatdoggy 11-24-2004 09:36 AM
RC12L3a - Car 2. *But* if you can't run a clean race the electronics may not make much difference. Track time is everything, if your not fast you won't be any faster with better electronics. However, if you can afford good electronics definately buy them, but only becuase it will save you money in the future. Good batteries can be bought very cheap Hurricane is selling 2 6 cell packs 1.165-1.169v 420sec for $70 and 1.165-1.169v with 390sec for $60. That's $20 to $23 per 4 cell pack. :nod: It's cheaper to buy matched packs then unmatched. Don't worry too much about the motor. Spend your money on the charger, esc, radio and servo and then buy high end batteries(1.18v+) and motors later on.
Just my take...
RC12L3a 11-24-2004 10:13 AM
http://www.team2r.org/html/modules/n...8#forumpost178
here are some pics of a track in southern China.
picco007 11-24-2004 10:50 AM
Nice Track....Looks like a great place to race :nod:
Switch Blade 11-24-2004 05:40 PM
Originally posted by 429racer
Switch Blade: the center shock determines amount and a little speed of weight transfer. The nut on the center shock controls the sag of the chassis and rear pod (and droop). Most of the time you want the chassis and the rear pod level. Now for the dampening the thicker the grease/oil you put on the slower the side to side (and a little forward) weight transfer will be as vice versa for thinner grease/oil. Most f the time people use Associated green slime or Trinity White Stuff on the front king pins. I believe there are a few differnet springs for the dampening post but I just use the standard factory ones provided. Hope this helps!
Thank you very much, I really appreciate the help.
sKiMpYbOy 11-25-2004 07:58 AM
hey guys,
what would be the best bearings to be used on the rear axle??? i have been using some cheap bearings for the past couple days and i have blown a bearing after every run!!! I am at the point of taking the car and throwing it away!!!!!!
dado11g 11-25-2004 08:20 AM
Originally posted by sKiMpYbOy
hey guys,
i got the same question
Scrad 11-25-2004 08:41 AM
edit.
gacjr0 11-25-2004 10:22 AM
1: don't hit stuff
2: don't crank down on the diff
3: double check the cone washer and hub to make sure it's not damaging the bearing
4: don't hit stuff
5: make sure you're axle isn't binding (the axle spacers line up) and it's shimmed side to side so that its not binding/too much play and the right width
RC12L3a 11-25-2004 12:17 PM
ok i know i have been repeating myself but still the questions:
1. which company makes foams that are as grippy as jaco pink for the rear and double pink for the front? (company name and "colour" mark for the foam pls")
2. which company makes the hardest and cheapest rim?
i hope to cut down practising costs by gluing my own tires
million thx:nod:
Still Bill 11-25-2004 12:41 PM
Big Bill,
For the most part, I am using Lex Tyler's original setup which relys on standard kit parts.
For tires, I have Double Pink fronts (initially cut to 1.75"/44.5mm) and White rears (cut to 1.95"/49.5mm).
Ride height is about 4.5mm/3.5mm (front/rear).
Not too sofisticated with gearing year. Have a 25 or 26 pinion with a 100 ring gear.
Watch out for the flanged bearing in the diff. Because it is under side load, it is prone to being damaged when you hit things. I just had to change mine last night.
sKiMpYbOy 11-25-2004 12:44 PM
what would be the best make of flange bearing to get for the rear axle????
