-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
tim fry 11-21-2023 01:17 PM
What is it that is being used to reinforce the body?
Aurora_007 11-27-2023 04:13 AM
Hey Guy's Question, I picked up a Trinity X-Factor 6.5t for Blinky 1/12th Mod what gearing and Timing would you recommend? with a 40.5mm rear tire
jasburrito 11-27-2023 07:34 AM
I think the reinforcement material is slot car body armor? 3m adhesive lexan. Not sure have not had a chance to ask. The sticky lexan body washers are racer edge? I am also gonna put mod motor in my practice 1/12. I think you wanna be around 88/22 ish 64p. I would start timing at like 30. I am gonna use a 4.5 boosted and start with 76/18 ish with 48p. Let us know what worked. I did run a mod 13.5 with 94/48 64p. Was a little too slow. So gonna go with 4.5
Robbob 11-27-2023 07:58 AM
Pro's and Cons of Running only 1 damper tube?
New Roche is using 1, CRC's test project is using 1
Seen others just use 1 but not really give a clear answer to reason.
DesertRat 11-27-2023 08:11 AM
If the dampener is flat and vented so it won't generate any internal pressure, there are no Cons. With the dampener tubes at an angle like they are on every double-dampener car, if you only had one dampener it would try to push the pod up or down as it actuated side to side.
silden 11-27-2023 09:53 AM
We ran a rollout of 50-55mm with 6.5 mod blinky.
keep in mind that you need to drive it like a 13.5 stock car.
aka no real fineness needed on the throttle
hanulec 11-28-2023 04:25 PM
Pro - lighter
Zerodefect 11-28-2023 06:10 PM
One tube with thick fluid is more consistent than two tubes with thin. Less maintenance as well.
Acid_CZ 12-14-2023 02:48 PM
13,5T justock gearing
I tried to search forums, but without much luck. What rolout for Hobbywing justock 13,5T on black (ETS) carpet?
PROMODVETTE 12-24-2023 09:20 PM
What shims are everyone using for front axles? The xray part number in the manual is over $1.50 a shim for .5mm thick. Surely someone makes a 1/8 id shim in a larger pack than 4 for a reasonable cost.
hunterdawg 12-25-2023 02:51 AM
You might try an RC oval company like Lefthandrc or Muddslide for those shims.
LonnyJ1950 12-25-2023 09:36 AM
https://www.amainhobbies.com/crc-1-8...ln4731/p235100
TonysScrews 12-25-2023 09:53 AM
Originally Posted by LonnyJ1950 (Post 16060907)
I use these to shim both my 1/8" X12 axles as well as the rotors in my brushless motors :D
bmwjoon 12-27-2023 08:49 AM
On the HW website the Kv is 200rpm higher than a 17.5 (stock timed) I would start with those type runouts. Depending on track size 70-90? With that motor start low.
Acid_CZ 12-28-2023 03:58 PM
Thanks, IŽll start with 70
