Originally Posted by racenut123
(Post 13936391)
What is the time to switch to blue in the rear? When you are looking for more or less steering? I hear the greene although softer, is suppose to create more steering overall. I have run X2Blue and Blue recently. They were pretty darn good but about 6 minutes in they pick up a slight mid corner to exit push.Would Green rears help? I am running your tires btw so I figure I would ask.
Europeans like the new Orange, not the Jaco orange. This is like a green but with a little harder. I have ran this a lot in MOD but haven't tried it in stock. Soft Green's or the new name (Yellow) are good but we start to get too soft with these, so they may not always be the best. I don't like explaining in terms of harder or softer because a lot of our tires are about the same shore rating, but the foam cell structure is different. To explain them that way I would need to go to school and get a chemistry degree :) I hope to have a chart available soon with all the color names and what each mfg. call's them. the current charts are all wrong. Not sure if I will put shore rating on the chart, but I need to put something so racers know what direction to go in if they want to make a change. Keep checking www.facebook.com/proonerc Steve |
LOL Not a single comment on the Buick Grand National GNX pics I shared earlier...I guess you see those every day. :rolleyes:
Anyway, maybe it's posted in the wrong section; I see there's a vintage 1/12 forum too, but since this is resto-modded with modern electronics, I wouldn't know which one to post it in. Some body-off shots of the car, I installed a 1S LiPo, Turnigy TrackStar Gen II 1-cell ESC, 17.5T Trinity Revtech Kill Shot motor I bought from another member here, fabricated a custom battery tray and hold-down, and fabricated my own custom bumper to protect the body. Chassis started with a vintage AE RC12L3. http://www.rctech.net/forum/members/...ont-bumper.jpg http://www.rctech.net/forum/members/...tional-gnx.jpg http://www.rctech.net/forum/members/...tional-gnx.jpg |
Nice job. But I would replace those wires with 16ga.
(Post 13936391)
Originally Posted by gubbs3
(Post 13936350)
As will all other things, not all CMMs are the same. While the most common will have a length measurement error of 2.5um+L/200mm and can be used right on a production floor, others go up to .3um+L/700mm and require temperature controlled labs which are more than capable of those tolerances. However, I highly doubt TKO would opt for the million dollar option when the $60,000 version will do well enough for our needs. But that still doesn't rule out that they may outsource their inspection process.
Unfortunately the rings alone won't make for a smooth diff. Axles and hubs are usually off far enough after a few good whacks where you'll get tight spots as you spin the diff. When you conduct a full measurement system analysis what you end up with is that for the purposes of sentencing a product with 99.997% certainty (3ppm defective; 1.33 Cpk) you end up with the 0,004mm number. We use all types of CMMs to sentence products you hand your life to when you travel. We don't want to scrap anything, so we know precisely what these things are capable of - and we have more than any other company in Europe! In reality it is exactly as you say - the flattest ring in the world bought at considerable expense and mated to a hub that is made to a tolerance 10 times bigger and probably bent in a big hit! You wonder why people bother...! :rolleyes: |
All of this about diff rings that go on hubs that aren't that straight, with diff balls that aren't perfect and spur gears that are slightly off :)
Originally Posted by Racermac73
(Post 13938197)
The smoothest diff I ever built used rings that looked like they had been run in a sand drag car for 20 years. Those things were GOUGED. Sanded them for about ten minutes (no hobby shops around, getting ready for a race in just a few days) and put it back together with fresh balls and a slapmaster. Smooth as butter. I'm still using those rings with just an occasional sanding.
I really don't understand how anal some people are about diffs. It's like it's become a competition for the smoothest, freest diff instead of the fastest car. Sometimes a stiff crunchy diff is actually better. |
Originally Posted by lpittman
(Post 13938200)
Was thinking the same thing! :)
Originally Posted by WIITA
(Post 13937084)
I'm not sure what pro one uses for foam but with the CRC Double blue front tires I have noticed that there is a slight push when running them with blue rears. When running blue rears I always run blue fronts as well to get just that little more responsiveness and steering. In 13.5 I love the green rear double blue front. It seems to me that greens rotate just a little more and allows the double blues to work well and keep the car calm with the extra speed of 13.5. Just my observation and what works for me.
Steve |
Originally Posted by TOADYY
(Post 13936902)
I also wanted to use blue wire, and all I had left was 14ga. :blush: |
(Post 13938197)
(Post 13938200)
Originally Posted by Coelacanth
(Post 13938339)
I stopped thinking...and yawned.
Originally Posted by SlowerOne
(Post 13939859)
WE bored you? Imagine my concern... :rolleyes:
Come on guys
1/12th scale is the fun Scale :D |
I've recently bought my first 1/12 in about 20 years, a used RC12R5.2 to run on 10.5 blinky. I bought some diff balls and new Kimbrough spurs to freshen up the diff. To my surprise the spurs take 12 balls but Associated sell them in lots of 8... Can anyone recommend alternative diff balls, or are the Associated ones good, but I'll need a few packs?
| All times are GMT -7. It is currently 08:26 AM. |
