Like Tree2991Likes
1/12 forum
Old 07-21-2015 | 08:47 AM
  #42931
jetnjme's Avatar
Thumbs up
very informative videos, thank you for sharing
jetnjme is offline
Old 07-21-2015 | 09:20 AM
  #42932
DirkW's Avatar
Originally Posted by Fran
Thanks for this tip. Where can we find this Topline tool?
Look for "ball end reamer" and you will find versions from turnigy, muchmore, etc. as well. Not too hard to find (once you know about them).
DirkW is offline
Old 07-21-2015 | 08:03 PM
  #42933
Fran's Avatar
Thank you.. I was looking for pivot ball reamer tool.
Fran is offline
Old 07-24-2015 | 06:45 AM
  #42934
what is a good receiver pack these days?
Patrick_Head is offline
Old 07-24-2015 | 07:18 AM
  #42935
Mach10_shooter's Avatar
http://www.smc-racing.net/index.php?...&product_id=85
Mach10_shooter is offline
Old 07-24-2015 | 08:38 AM
  #42936
Skiddins's Avatar
No one in the UK runs receiver packs;
http://www.rcdynamics.co.uk/Booster.html
http://www.rcdynamics.co.uk/News.html
Skiddins is offline
Old 07-24-2015 | 08:46 AM
  #42937
Originally Posted by Skiddins
I've been testing this one in both stock and mod.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
So far it's holding up.
Oh and the price is right!!!
Old 07-26-2015 | 02:17 PM
  #42938
bdmpastx's Avatar
Originally Posted by EDWARD2003
Check out this video on the importance of bind free lower suspension balls.
https://www.youtube.com/watch?v=m2Q8UeTLjyk
What you are showing is known as bump steer. Those lower suspension balls are not causing bump steer. I can assure you that 100%. Bump steer happens when the upper arm pivots and the steering linkage are on 2 different pivot angles. You can eliminate bump steer by changing the angle of the linkage on the steering turnbuckles by adding or removing shims. This happens on real cars as well as RC cars. Here is a picture to explain bump steer.
bdmpastx is offline
Old 07-26-2015 | 02:47 PM
  #42939
Exactly...Bump steer is caused by differences in suspension angles. Most likely what was causing your car to handle strangely due to the ball being too tight is that a pivot ball that doesn't move smoothly will cause the king pin to bind so you will either not get full suspension compress, suspension will not fully release, or the suspension will move slower than it should due to the increased friction between the pivot ball and the king pin.
InspGadgt is offline
Old 07-26-2015 | 05:20 PM
  #42940
EDWARD2003's Avatar
Yes, you are both correct with identifying what bump steer looks like.
However, in the video I purposely avoided mentioning this bump steer (height of the steering links), because it wasn't the steering links causing the bump steer in the video. The main reason for the video was to show the importance of why the lower and upper suspension balls should be bind free.
I do appreciate you pointing this out bdmpastx and InspGagt.
https://www.youtube.com/watch?v=BNTY1n5jdTY
TN Racing Tire Rack
EDWARD2003 is offline
Old 07-27-2015 | 05:10 AM
  #42941
EDWARD2003's Avatar
A neat little differntial plate sanding tool which I stumbled upon on Yahoo Auction Japan.
https://www.youtube.com/watch?v=RMVT0jJWsVk
Old 07-27-2015 | 05:39 AM
  #42942
bdmpastx's Avatar
I just picked up the stuff to build this exact thing...how crazy is that.
bdmpastx is offline
Old 07-27-2015 | 07:57 AM
  #42943
TOADYY's Avatar
IRS also has a diff sanding tool.
http://www.lefthander-rc.com/catalog...oducts_id=2653
TOADYY is offline
Old 07-27-2015 | 09:39 AM
  #42944
There really is no need to buy a special diff sanding tool. An old diff hub (or even the one off your current car) works just the same. One word of caution though....if you do use your current diff hub to hold the diff ring while rubbing it on emory paper.......be sure to remove the bearing(s) first. You surely won't want to take a chance of getting any of the grit from the sanding operation into the bearings.
vafactor is offline
Old 07-27-2015 | 10:08 AM
  #42945
bornox's Avatar
Default Need help understanding rollout
i'm new to 1/12 pancar i need some help how does the rollout work? the higher the number the faster and why are the tires need to be true. Does it affect the speed?
bornox is offline
