Like Tree2991Likes
1/12 forum
Old 09-22-2012 | 03:55 PM
  #38326
I had a couple 150mm sensor wires laying around... both the CRC and TQ versions. It appears that one of the brands is about 15mm longer than the other. One company probably measures from end to end, the other from where the wire itself stops.
Sooo... with that said, does anyone know which is which? ie: for a given sensor wire length, is the TQ or CRC version longer?
JamesL_71 is offline
Old 09-22-2012 | 06:59 PM
  #38327
silvalis's Avatar
Originally Posted by HBRC-LBD
Hey Silvalis,
Setup is all stock at the moment just played around with weight to try make it better.
Are associated springs compatible with the X12?
Cheers
Pretty sure the associated springs work on it, but I've never tried it so couldn't tell you.
This is what mine looks like atm. I'm a noob at 12th, not really sure how to set it up properly. Couldn't for the life of me set the front/rear tweak properly, couldn't get it to track dead straight under acceleration. So I dodgy'd it and stuck a bit of weight on the rear pod, near the motor pinion. Now it tracks straight under acceleration on tiles, so I'm not going to touch it...
DSCF0903 by silvalis, on Flickr
silvalis is offline
Old 09-22-2012 | 07:44 PM
  #38328
CypressMidWest's Avatar
Originally Posted by V12
Someone remember the first CRC cars using rear wheels of the old 2 hole system? Did CRC have their own wheels that time? Any pictures?
No CRC wheels back then. It was all TRC, TM and Jaco. The first CRC wheels were the three -bolt dish wheels released later.
CypressMidWest is offline
Old 09-22-2012 | 09:37 PM
  #38329
LonnyJ1950's Avatar
Originally Posted by Csaari77
I just got my Rectech pack and I have a question about charging it. It comes with 2 leads, and one looks like a balancing plug. I assumed this is a 1s pack, so why a balance lead. Can I still charge it using the receiver plug?
You can charge it with either plug. One plug is wired into the switch, the other is a hot plug. The idea is to put the plug with the switch into the receiver, then you can charge using the hot plug without removing the other plug from the receiver, or turning the switch on. Believe me pulling the plug out of the receiver every couple of runs gets old really fast. It is a 2S, but being a LIFE pack and low MAH, balancing doesn't seem to be a problem, and there's no balance plug anyway.
LonnyJ1950 is online now
Old 09-22-2012 | 11:00 PM
  #38330
Most importantly, be sure your charger is set to Life mode and not Lipo mode.
linkless is offline
Old 09-23-2012 | 10:11 AM
  #38331
Logi Maker's Avatar
Anyone know of a "generic" adjustable body mount system like the Serpent car has? I thought I saw it somewhere and was looking to get them for my 5.2...
http://www.amainhobbies.com/product_...y-Adjust-Nut-4
Logi Maker is offline
Old 09-23-2012 | 03:43 PM
  #38332
wingman2's Avatar
I have used Corally post for many years and never had a problem with them.
wingman2 is offline
Old 09-23-2012 | 04:15 PM
  #38333
Logi Maker's Avatar
Saw those, are the posts themselves threaded or is it a 2 piece deal?
Old 09-23-2012 | 04:32 PM
  #38334
Do racers still run a bead of CA along the side of the chassis plates on carbon fiber cars?
DEACON is offline
Old 09-23-2012 | 04:50 PM
  #38335
wingracer's Avatar
yes
wingracer is offline
Old 09-23-2012 | 09:13 PM
  #38336
mdwalsh's Avatar
how fragile are 1/12th scale cars? im interested in getting one after running them on vrc for the past week.... im a decent driver and i race a stock sedan currently. but how is the durability of the arms and such? is the chassis easily tweaked?, are they difficult to set-up? im a total noob when it comes to pan cars.
Matt
mdwalsh is offline
Old 09-23-2012 | 09:22 PM
  #38337
RedBullFiXX's Avatar
Matt
12th scale cars are very light 730g
When they bounce off things they do not generate forces of impact like sedans
So they don't brake or bend much at all
Obviously, if you are a very poor driver and find it difficult to keep the car on line & in the lane, you will chuck a fair share of foam tires
Aside from that, they are quite durable little cars
I would describe setup as different, but not difficult
No tweak station needed, just a ride height gauge, and a set of callipers will do the job
Check the 12th scale link in my sig for tons of info
RedBullFiXX is offline
Old 09-23-2012 | 11:55 PM
  #38338
Logi Maker's Avatar
What chassis is this?
Old 09-24-2012 | 12:13 AM
  #38339
silvalis's Avatar
Xray X12
With a team epic foam bumper stuck on it
silvalis is offline
Old 09-24-2012 | 12:18 AM
  #38340
Robert_K's Avatar
Yokomo has really nice (blue) ones:
http://www.rc-race-and-drift-japan.c...es/zs-abm5.jpg
Yok ABM-5
Regards Robert
Robert_K is offline
