Like Tree2991Likes
1/12 forum
Old 01-11-2012 | 05:58 PM
  #37501
LonnyJ1950's Avatar
Where do you even find 52mm rears? (or fronts for that matter)
LonnyJ1950 is offline
Old 01-11-2012 | 06:36 PM
  #37502
sepsep's Avatar
SPEEDMIND 1:12 Foam Tires, im using f32 r30 quite good for asphalt track.
Attached Thumbnails 1/12 forum-21111288959625_809_m.jpg
sepsep is offline
Old 01-11-2012 | 07:06 PM
  #37503
DesertRat's Avatar
Thats enormous, you could set it up so that the car had like 12mm of ground clearance , which is just strange, with the Prototype body on there it would look like a Porsche Cayenne, which is like a 911 with elephantiasis
DesertRat is offline
Old 01-11-2012 | 07:37 PM
  #37504
sepsep's Avatar
hehe... easy use ride height spacer/shims adjust to 4mm F&R.
before im had use matrix (45mm) and xceed (48mm) foam tires.
For asphalt, SM hv more hard shore and long life. their rear
wheel hub very well designed.
sepsep is offline
Old 01-11-2012 | 08:04 PM
  #37505
LonnyJ1950's Avatar
The tires on my WGT are only 53mm!!
Old 01-11-2012 | 08:12 PM
  #37506
DesertRat's Avatar
And a Jaco Prism wheel for Touring Car is 52mm!!! The old stuff smaller!
Old 01-11-2012 | 08:15 PM
  #37507
Arahawak's Avatar
Originally Posted by chris moore
Well its possible if the asphalt is in very rough shape, and if it is that rough running 1/12 is a real challange.
The local track is pretty rough, so I guess we have to keep in mind the wear rate too.. Most 12th scale tires comes 46 to 50mm..so it's going to be a challenge.
Thanks for all the input
Arahawak is offline
Old 01-12-2012 | 08:25 AM
  #37508
Originally Posted by jdeadman
attached guide
Don't forget that after we started with liop all the rules changed
and some time things that did work that way now work a different way, the best is to test it. And play and test new settings.
I have be surprise more than one testing new things.
But yes this guide can be a nice starting point. nice work.
Alf
alf.skaar is offline
Old 01-12-2012 | 03:18 PM
  #37509
DesertRat's Avatar
Has anybody on here tried a Novak Velocity Lite in 1/12 scale? I am seeing them in the Stormer bargain bin and I don't know if they are worth the time.
Old 01-13-2012 | 03:58 AM
  #37510
ammdrew's Avatar
Company Representative
lite winds are a great drive. 4.5l or 5.5l will rpm the same but not as aggressive off the corner allowing a lot more drivability for many.
ammdrew is offline
Old 01-13-2012 | 09:32 AM
  #37511
Arahawak's Avatar
I am almost hook on getting a 12th..
just want to know what is good average speedo to go for and servos?
Savox/Futabas...
Arahawak is offline
Old 01-13-2012 | 10:10 AM
  #37512
RedBullFiXX's Avatar
Savox/Futabas...
There are a list of options on The 12th scale Thread HERE
RedBullFiXX is offline
Old 01-13-2012 | 01:49 PM
  #37513
Bob-Stormer's Avatar
I've run them and found them to be an excellent motor. Very smooth and drivable.
Bob-Stormer is offline
Old 01-13-2012 | 11:30 PM
  #37514
DesertRat's Avatar
Thanks Bob, I think I may grab one with my next order if there are any left.
I have a better Chuck Norris joke for you though: Chuck Norris once went to The Virgin Islands...
When he came back, they were just The Islands.
Old 01-13-2012 | 11:41 PM
  #37515
that's a good one.
