Like Tree2991Likes
1/12 forum
Old 06-15-2011 | 05:14 PM
  #36001
CypressMidWest's Avatar
Originally Posted by davidl
Come on, Ian. Tell the truth. You were one of the 10 best drivers at those events in your classes. You are quite the wheel , you know.
Thanks David, but I give all the credit to the equipment. My driving talents aren't what they used to be.
CypressMidWest is offline
Old 06-16-2011 | 09:05 PM
  #36002
scooterman1995's Avatar
Default TC5R trade for CRC 12th.
i have a TC5R ran on only carpet and tennis court grade asphalt. i would like in return a CRC gen-x
scooterman1995 is offline
Old 06-17-2011 | 08:29 AM
  #36003
gruman28's Avatar
Does anyone run the novak 1s in there 12th scales? I was thinking of getting one to run 17.5 blinky? Novak says it doesnt need a rec pack or booster. Thanks for any help?
Chris
gruman28 is offline
Old 06-17-2011 | 10:32 AM
  #36004
odpurple's Avatar
Chris
The Novak Havoc has an internal booster. The heat sink looks too tall but there is a low profile one available. I have been running the Kinetic 1s esc for non-boosted 17.5 and it works great,very smooth and fast. It does require a receiver pack but it comes wired for it and runs the rec pack through the BEC of the esc so there is no concern about voltage with lipo rec packs
odpurple is offline
Old 06-17-2011 | 10:32 PM
  #36005
noline's Avatar
Anyone Know what is the best lipo charger for 1/12th 17.5 and 13.5 blinky money is no object.I picked up some thunder power and Revtech packs and need a top level charger.
noline is offline
Old 06-17-2011 | 11:37 PM
  #36006
andrewdoherty's Avatar
I don't think there is a bad charger on the market. Pick a small one that you like the looks of and have at it. I use this one
http://www.hobbyking.com/hobbycity/s...idproduct=7028
andrewdoherty is offline
Old 06-22-2011 | 01:25 PM
  #36007
dkrall's Avatar
Hey guys,
Slight problem here. I was putting together my DB12RR, (I'm using a Speed Passion Stock Club ESC, a Spektrum SR300, a Spektrum Dual Regulator, and an Rx pack, as well as a Reedy 1s battery) and whenever I turn on the switch for the receiver pack, everything turns on and the Rx pack powers the whole vehicle. Not sure if this is due to a wiring error caused by me, or if something is wrong with one of the electronics. Leaning towards an error by me. Has anyone ran into this before or know how to fix it?
Thanks in advance.
dkrall is offline
Old 06-22-2011 | 05:38 PM
  #36008
LonnyJ1950's Avatar
The receiver pack should only plug into the receiver, it should not be wired to anything else. There should be a switch that only turns thr RX pack on and off, when you turn it on the RX should be powered, the servo should work and the ESC should come on, but the motor should not run unless the 1S pack is plugged in. Can you post a pic of your car?
LonnyJ1950 is offline
Old 06-22-2011 | 06:48 PM
  #36009
dkrall's Avatar
So do I not need the regulator? I'm confused. I can post a picture in a little, but my camera isn't all that great and quite frankly the wiring looks like a mess at the moment...
The motor seemed to be extremely low powered, but it was still turning. The servo seemed up to the right speed, but this is my first 1/12 scale, so I'm not positive about that either.
dkrall is offline
Old 06-22-2011 | 08:52 PM
  #36010
LonnyJ1950's Avatar
See my post in the DB12R thread. Following this discussion in 2 threads is making me dizzy. Be sure you go thru the process to turn off the the voltage cut off using a 2S set up. You do need he voltage regulator for the 2S RX pack.
Old 06-23-2011 | 04:32 PM
  #36011
KAHUNA's Avatar
Cool Ian Who !
Ian Ruggles on the Gen XL do they make the servo stays so I can lay it flat ( and red ) , Or does anyone know this and where can I get them !
me
KAHUNA is offline
Old 06-23-2011 | 04:36 PM
  #36012
KAHUNA's Avatar
Cool
You got that right !
Originally Posted by RedBullFiXX
QFT !
If it wasn't for Cyrul, Yokomo, AE, & CRC "Team" drivers would win every race, with cars that are not "KIT"
On-point Serpent conversions are cool too.
KAHUNA is offline
Old 06-23-2011 | 05:04 PM
  #36013
RedBullFiXX's Avatar
He's a Bad Dude in 12th scale !
RedBullFiXX is offline
Old 06-23-2011 | 05:20 PM
  #36014
http://www.teamcrc.com/crc/modules.p...prodID=7719157
mahamoti is offline
Old 06-26-2011 | 10:01 AM
  #36015
Default old school 1/12 ae 12l3-4
Will this work? Will a 1s havec 13.5 system and a single saddle pack which is 3.7v, 5000, 30-50c work?
steven57rc is offline
