Why would they treat the track with WD40?
Originally Posted by wingman2
(Post 6981329)
Hi guys, does any know, or can anyone tell me who makes the motor shaft extender? I run a Corally car that uses long boss pinions but can't get big enough long boss pinions to get the correct gearing. I have loads of big 'standard' boss pinions so I thought the extender thing would be the way to go. any help is appreciated! Cheers.
Thanks guys.
RC12 5R Front End Kit
can one be bought as a complete kit? |
Originally Posted by InspGadgt
(Post 6986909)
Originally Posted by avs
(Post 6986874)
Hi Adrian, could you reccomend an approach for an indoor asphalt track (WCRC in california). the bite is very high(grip like carpet but cold, hard and abrasive), the asphalt mix used has no visible rock, just tar and very smooth. they occasionally treat the track in spots with WD-40.
FYI, using black/grey with JTG works ok, but i am struggling to get a natural rubber tire choice to work for better wear characteristics. i thought i was close with purple/magenta and 24 front spring (bmi) and short thick gr/ep flexbars and copper center spring. but it is still touchy. could suntan lotion make the front more predictable? If the traction is really high you might what to try going in the other direction with car setup. The carpet guys run their cars pretty soft when the traction is high. Stiff cars have very fast weight transfer and this makes them feel very touchy and can lear to traction rolling. Try the long thin fiberglass flex plates with fairly light rear damping in the tubes, a gold rear spring and .022 front BMI springs. This will let the car roll more and smooth it out. |
Originally Posted by AdrianM
(Post 6987903)
Suntan lotion might work. You will just have to try it.
(Post 6987862)
It softens the actual asphalt oil that binds the rock/gravel/sand aggregate and increases traction...pretty dramatically. This only works on clean indoor asphalt tracks where the asphalt never oxidizes (no rain, UV exposure indoors).
Gadget, I was having the same problem when we went to LiPos over here. What I figured out was going to purples in front with either a .022 or .024 asc. front springs with the pinks in the rear. I have been using this on my OD12/L4 conversion car. I got so tired of the 12r5 just mot staying planted enough in the rear that I went back to a t-plate car. However one of the other guys tried something simular and it worked for him as well. This was even with the track treated with sugar water.
(Post 6987903)
(Post 6987862)
(Post 6988450)
ok, that makes sense. but what tire choice would you suggest working towards? ie; synthetic high wear, or natural low wear?
The goal is to use the hardest tires you can but still have the steering and traction that you need to go fast. Soft foam has more inherent traction and rolling resistance. For most of the aspahlt tracks I go to I start out with double pink front and rear. If traction is crazy and I need to tone down the steering then I go to Lilac fronts. I rarely have to go to pink rears. They have more forward bite but not much more side bite than double pinks. |
Originally Posted by Mugen10
(Post 6987991)
Hmmm, I thought when traction is really high you go stiffer to keep the car from chassis roll. A high grip track with a softer setup will cause the car to bog down in the corner with to much grip right?
With a softer setup, you let off the throttle, turn and the chassis rolls. Some of the energy is absorbed by damper tubes and front springs. The increase in pressure on the tires contact patch ramps up more gradually and the car drives smoothly and more predictably. Stiff setups also wear tires faster. Its all a balancing act. A fast car uses tires and suspension together. |
(Post 6988942)
Try Lilac fronts and Double Pink rears.
The goal is to use the hardest tires you can but still have the steering and traction that you need to go fast. Soft foam has more inherent traction and rolling resistance. For most of the aspahlt tracks I go to I start out with double pink front and rear. If traction is crazy and I need to tone down the steering then I go to Lilac fronts. I rarely have to go to pink rears. They have more forward bite but not much more side bite than double pinks. Before when i tried those tires and softer suspension the car would be balanced in a drift, but if i let off a little or got a little too sideways then the car would bog a little, then the tires would grab and the car would dive into the inside board. i was also running the tires a little too big maybe? (42.5/45.0) with black/grey the traction was smoother with varying slip angle, but with 2xpink grip was more like an on-off switch. thanks again for your help on this. |
(Post 6989515)
i will have another go in a soft direction like you suggest.
Before when i tried those tires and softer suspension the car would be balanced in a drift, but if i let off a little or got a little too sideways then the car would bog a little, then the tires would grab and the car would dive into the inside board. i was also running the tires a little too big maybe? (42.5/45.0) with black/grey the traction was smoother with varying slip angle, but with 2xpink grip was more like an on-off switch. thanks again for your help on this. Also, you may want to try Trinity Zip Grip as a traction compound too. |
| All times are GMT -7. It is currently 01:41 AM. |
