I need some help with dampener tube lubes. The set ups I see list 5000 wieght diff lube or Shurlube. I have the CRC stuff. Which Shurlube and CRC lube compares to 5000 weight diff lude? Which is better Shurlube or the CRC stuff?
Casper--Thanks for the advice. That's what I have planned to do. I was sure if there was a device that made it a little easier.....Cause I've got an idea on one.(At least for 12th scale's) Maybe more.
I think it was trinity who used to make some pointy cone things you would screw on to the top of the body posts that you could then push down on them to "dimple" the body in the right spots. I am sure they were not cheap though and there are other ways of doing this. Like I said if you were to mark them before you paint is the easiest way but if you buy a prepainted body this is not always the option.
Originally Posted by Juan C Munoz
(Post 5979862)
Is there any guide on how to setup the Serpent S120 ?
I'm new at Electric On-Road cars and having real trouble finding the right setup for my car. I was hoping if you guys can direct me to a guide that explains to me the trick to setup my car for any track. Thanks
Originally Posted by SwampDog32
(Post 5979904)
could not find on trinity site, but http://www.ehobbies.com/tri30003.html
My tires are down to 41mm with a 3mm spacer gets me to 4.0 mm
Is this about the lowest I can go? Track allows 3.5mm Thanks |
Originally Posted by rinkrat99
(Post 5980802)
Chris,
Is there any way to get a lower ride height if the 3mm adjuster is deemed too large to get a ride height? I would think 41mm is failr y close to the death of the tire. |
Yea at 41mm you are getting close:lol:. You can take the 3mm spacer out but you will need to use a 2mm washer for each screw. By taking out the spacer you lose some strength in that lower arm and if you take a hard hit to the front its very easy to bend the screws and tweak the car. By using a small thin 2mm washer between the lower arm and the chassis at each screw you add back some strength to the lower arm. I found some at a local Ace hardware store.
Originally Posted by Khador12
(Post 5979870)
Greetings, Luis C. |
I am now in the difficult task of changing the car, took a few years running with
CRC, and I want to change, i am undecided between these 2 models, BMI db12rr or Speedmerchant rev5, both are very similar to my GEN-X, i like the design of the BMI, but the Speedmerchant are very interesting, too, but i donīt can buy the 2 cars. I would like to hear views from both pros and cons, etc... I race in asphalt, low grip tracks, some time in carpet, but rarely. Thanks in advance, Luis C. |
Originally Posted by luic
(Post 5985405)
(Post 5985405)
CRC, and I want to change, i am undecided between these 2 models, BMI db12rr or Speedmerchant rev5, both are very similar to my GEN-X, i like the design of the BMI, but the Speedmerchant are very interesting, too, but i donīt can buy the 2 cars. I would like to hear views from both pros and cons, etc... I race in asphalt, low grip tracks, some time in carpet, but rarely. Thanks in advance, Luis C. Two excellent choices. BMI great car, durable and plenty quick good luck... Viva Las Vegas |
Both great cars, but so is your old one. :D
(Post 5985405)
| All times are GMT -7. It is currently 12:24 AM. |
