Is it a better tuning/ set-up option to use the tweak screws or the side springs on the T-Fource?
Originally Posted by JRX-S Bill
Undecided about HW on Friday; but, may come sometime during the weekend to practice. The 3 Wise Men have already said no to racing tomorrow.
The JRX-S is not quite dead...Will probably be testing it with foams. Bill |
Does anyone know what is happening with CEFX? I see David Spashett over here ran a Trinity switchblade in the last 1/12 national not his usual CEFX.
can anyone feel a difference in handling in thier cars between a boddies? i think my speed 8 has a little less front down force then my CEFX... but its hard to tell. does anyone else feel a difference. if so what body does what. speed 8, speed 12, CEFX...
Yokomo YRX-12 WE
Anyone interested in a Yokomo YRX-12 WE for the upcoming outdoor season, I found these on Ebay.
http://cgi.ebay.com/YOKOMO-YRX-12-WO...QQcmdZViewItem http://cgi.ebay.com/Yokomo-YRX-12-Wo...QQcmdZViewItem |
12L4 front end question
On the 12l4 front end the stock setup from the top of the king pin is e-clip/3 washers/top arm/washer/steering block/bottom arm/
spring/e-clip....Questions: Will increasing the amount of top washers lower the roll center and give more agressive steering? Also, does anybody have any info on spacing up the front t-bar pivot for a lowered roll center? And will this increase traction? Tire question: Any body running BSR foams? What is difference between BSR purple,Jaco purple and Parma purple. |
spring/e-clip....Questions: Will increasing the amount of top washers lower the roll center and give more agressive steering? Also, does anybody have any info on spacing up the front t-bar pivot for a lowered roll center? And will this increase traction? Tire question: Any body running BSR foams? What is difference between BSR purple,Jaco purple and Parma purple. I believe Jaco and BSR use the same rubber, but PARMA rubber is different. The feeling I got was that PARMA and TRC tires have a bit more grip for the same compound shore rating than the Jaco/BSR style rubber. |
Originally Posted by G Ace
If you use the springs instead of the t-bar screws your tweak setting should last a lot longer between adjustments (especially after a crash) and it should make the t-bar last longer, since it allows the entire t-bar to pivot instead of constantly twisting the t-bar.
IRS Rear POD System
Is anyone running the new IRS 4 post rear pod system on their L4? I picked one up yesterday and installed it, but I have some questions about it. When I tighten down the top plate it preloads the lower spring of the dampner disk, and the top spring has very little tension on it. Is there something missing that I did not do correctly?
J,
The pre load on the lower spring is due to the pod plates being .080" shorter in height than the other IRS pod plates. D.P. |
IS there something i need to do to correct this or do I just put it together and run it like that?
To have the correct amount of preload on each spring, the chassis brace needs to be lowered the same amount. That means the 3 posts that support the brace will have to be shortened.
D.P. |
i always thought that the lower pods were just lower mount of the axels. it sounds like lowered pods is basically taking material off the bottom of the pod bulkheads. that seams wrong to me.
| All times are GMT -7. It is currently 11:07 PM. |
