be aware that even .2sec a lap difference for 40 laps, that is 8 sec. that is probably close to a lap difference
I really wanna see saddle pack lipos--any backyard "engeniering"been done .
like on some helio packs wired in parallel to get the Mah up? |
On the oval track I run the 17.5 4 cell and 13.5 1cell are pretty equal. The 27T is a little slower probably .3 to .4. Might not be fair as the 27T are usually slower drivers.
Originally Posted by RAL
(Post 6442524)
I know at our local carpet track these are your options for "stock" all combo's are looked at as equal. Don't know if it really is. I'm sure the gurus on here can tell you. I'm curious as well as to how they match up.
27t 4cell 17.5 4cell 13.5 1s lipo |
Originally Posted by kn7671
(Post 6437526)
Just better! :lol:
Originally Posted by GasGod
(Post 6442988)
like on some helio packs wired in parallel to get the Mah up? http://www.rctech.net/forum/electric...00mah-30c.html |
13.5 3.7v does the same laptimes as 13.5 4 cell. So no it is not equal to 17.5 4 cell.... The bigger part of the picture is the corner speed vrs straight speed. Laptimes for 3.7v with the 10% drop in wt gain all the hp loss back in corner speed and run the same laptimes but in a rd course environent it makes for a messy race as if you have similar skilled drivers the flow lines are different through corners and into the straights.
Anyone know where I can find a 17.5 Duo2 "in stock"? Seems to be on back-order eveywhere.
Originally Posted by ammdrew
(Post 6446191)
I know the W. Washington guys (Bodine, DuTemple, et al) have decided that 1s / 13.5 and 4-cell 13.5 run together acceptably well. The Fantasy World Summer Sizzler (25th Annual!!) allowed either of these specs and the main proved to be a duel between Mike with a 4-cell car vs. Brian with a 1s car. Bodine made a small mistake early and spent 6 minutes running several seconds behind but the gap was pretty much the same throughout. With 1 minute to go the 4-cell car began to slow noticeably (geared pretty aggressively to keep ahead of the BodineMachine) to near full dump at the end where he won by a second or so. Had the race been even one more lap (heck...one more corner) and Brian would have had him. |
[QUOTE=Scottrik;6446629]
(Post 6446191)
13.5 3.7v does the same laptimes as 13.5 4 cell. So no it is not equal to 17.5 4 cell....QUOTE]
Testing here showed that with the same gearing a 1s / 13.5 was VERY close to the same as a 4-cell / 17.5. But when we started gearing the 1s / 13.5 up to where it was optimized it was significantly faster than the 4-cell / 17.5 is. I know the W. Washington guys (Bodine, DuTemple, et al) have decided that 1s / 13.5 and 4-cell 13.5 run together acceptably well. The Fantasy World Summer Sizzler (25th Annual!!) allowed either of these specs and the main proved to be a duel between Mike with a 4-cell car vs. Brian with a 1s car. Bodine made a small mistake early and spent 6 minutes running several seconds behind but the gap was pretty much the same throughout. With 1 minute to go the 4-cell car began to slow noticeably (geared pretty aggressively to keep ahead of the BodineMachine) to near full dump at the end where he won by a second or so. Had the race been even one more lap (heck...one more corner) and Brian would have had him. And yes Brian would have needed one more corner. My 9 month old cells had had enough. |
Originally Posted by AdrianM
(Post 4094783)
Please copy and paste this into MS Word so you have saved locally:)
Building a Diff I use plain chrome steel diff balls from BMI, IRS, anyone...they are all the same high grade 1/8" ball bearings. I like to use Schumacher U1301 silicon diff grease or Associated silicon diff grease, the thick type in a plastic cup not the stealth grease in a squeeze tube. Stealth grease is too thin and gets flung out too easy. The diff balls I buy come in a 100 pack for ~$8. I open the pack over a clean paper tower and dump them out. All diff balls have a coating of oil on them to protect them while they sit on a shelf. I use motor spray carefull to wet them and then roll them on the paper towel to dry them. I then dump them all into the cup of diff grease. I keep them there untill I use them. When I build a diff I sand both sides of the diff rings with 600 grit wet-dry sandpaper lubricated with a little motor spray untill I see an even finish across the face of the rings. I then clean the rings with motor spray and dry them on a clean paper tower. Be sure to clean your finger tips with motor spray before touching the diff balls or rings. If you get any bearing oil or traction compound on them from your fingers it will contaminate the diff and mess it up. I then pluck the diff balls out of the diff grease cup with a small clean flat blade screwdriver and put them in the spur gear. They will carry all the diff grease they need with them. You do not need to put more on the rings. I put a ball in all 12 holes in the outer circle. The inner circle of holes is for the no longer used small diameter "Stealth" diff rings. Assemble the diff normally but tighten it slowly until you just start to get diff action. If you overtighten it you can dimple the rings and flat spot the balls. Tighten it and check the gear for slipping. As soon as the gear starts to get hard to slip stop. Mount some tires on the axle. Hold one tire and the gear locked and force the opposide side to turn a few turns. Repeat with the other side. This is called cutting the diff. Cutting the diff smooths out any imperfections in the rings and balls by burnishing them. The diff may have loosened a little from cutting it so readjust it so the gear is very hard to slip (this is tighter than the previous step). Install a motor and put the car up so the wheel are not touching the table. Run it at meduim throttle and alternatly touch one tire then the other untill it just stops then let go. This will heat up and fling out excess diff grease as well as breaking in the diff. Do this a couple times per side. Re adjust the diff a final time so it wil not slip and you are done. The diff should be glass smooth. It should spin very freely as if it were really loose but the diff gear should be almost impossible to slip. If the diff is gritty with new rings and balls replace the outer right side hub bearing. If the diff is slipping you have some petroleum oil contamination in the diff. Take everything apart and start over after cleaing everything with motor spray. |
Thank you for re-posting this !
Originally Posted by Scottrik
(Post 6446629)
I know the W. Washington guys (Bodine, DuTemple, et al) have decided that 1s / 13.5 and 4-cell 13.5 run together acceptably well. The Fantasy World Summer Sizzler (25th Annual!!) allowed either of these specs and the main proved to be a duel between Mike with a 4-cell car vs. Brian with a 1s car. Bodine made a small mistake early and spent 6 minutes running several seconds behind but the gap was pretty much the same throughout. With 1 minute to go the 4-cell car began to slow noticeably (geared pretty aggressively to keep ahead of the BodineMachine) to near full dump at the end where he won by a second or so. Had the race been even one more lap (heck...one more corner) and Brian would have had him. I can say that for those that are holding onto their 4 cells..... let 'em go! The 1S pack is the brushless motor of batteries. It's true that we are giving up on the best cells that we have had since the Sanyo 2000's, but get over it. You will be happier for it. Brian |
Originally Posted by Slapmaster6000
(Post 6451320)
I would like to point out this was on asphalt out doors on a 80x 120'ish medium turn type track. Take this scenario to a 40x90 carpet track and I feel that you will see the 4 cell car has a .2ths advantage. Moral to the story is; even with weight allowances, I don't think that you will achieve a true evenness between 4 cell & 1S.
Originally Posted by mkdut
(Post 6451351)
Anytime I can pick up 2 tenths on you I am happy. Makes for some pretty equal racing.
3 cell nimh vs 1S???
20 tenths :lol: Next you'll be asking for 2 seconds! :D
You know, just for conversation..... has anyone tried 3 cell nimh against the 1S format with equal running weight? I know that you would have to go through all the booster/rx pack stuff for the 3 cell car, but would it ease the transition of the nimh guys into 1S and keep a club from splitting up the 12th scale classes? Let's just suppose there is a club the runs about a dozen 12th scale cars, some are moving over to 1S while the others are left behind due the economy or what ever. I would guess that you could have the 4 cell guys drop a cell and have the new minimum weight be something like 800g for everyone. Sure, there will be some weight balancing to do in the chassis, but could it work? Will chargers correctly peak off 3 cells? The idea is.... a 4 cell guy would have just a few more race packs. And when the time comes, the switch over to 1S wouldn't be drastically different to the equipment once the budget allows it. |
| All times are GMT -7. It is currently 02:49 AM. |
