Originally Posted by mrhenning11
(Post 3680498)
Do you have a part number?
Thanks |
O.K. this might be a silly question but where can i get the carpet used for indoor racing? I have access to a small warehouse and would like to practice on it.
Originally Posted by odpurple
(Post 3677946)
Thanks for the compliment :)
One thing I forgot to mention about tires and asphalt: Experiment! different aggregates have different bite characteristics so sometimes the "normal" compounds/diameters/sauces don't work. How the surfaces are sealed or not, how porous it is and what is sprayed onto it can make a big difference. We've even run into situations where the best tire to use is good old greens (thankfully not often) :cool: We (in New Zealand) don't run tyre compounds, or any additives on the track. But we seem to have the right setups to put some good laps / times in :) |
(Post 3679426)
Hello,
I have a question on mounting the servo. It seems 50/50 on how people mount them. I think I want to mount mine flat. My question is how are you guys doing that? I can’t seem to find a mount made to do that. This is for a 12l4. Thanks Mark Most people use shoe goo to mount flat servos. When you want to remove the servo it come off if you twist the servo. The remaing stuff on the chassis and servo just peels off. If you mount the servo flat you must get taller med height ball studs for your steering spindles or you will have horrible bump toe in. Don't use servo tape. Its too thick and makes the bump toe problem worse. Flat servos are for carpet and angles servos are for asphalt. Flat servos generate less ackermann and make you car scrub less speed in the corners. On asphalt you need the ackerman to get more steering. |
OD, do you have a puck conversion for the OD12? P2 had told me what to do to put a puck on the OD12, but I know I would mess it up, and it would look all jacked up.
Originally Posted by CarlosG.
(Post 3688400)
Paul was running car that way for a while and liked it, but since he went to tubes he likes it better that way. I was going to do a damper disc version but lost interest after P2 quit running it that way. I may still do it at some point, but its not high on the list, to be honest. If you want to try it I can get together with Paul and make up a kit you :cool: |
(Post 3689345)
Your confidence is underwhelming! :lol:
New 1/12th car : VantommeM12
Hi,
a new 1/12th (another one?:nod: yep!) car : http://www.rctech.net/forum/showthread.php?t=182337 A Linked-car with extreme sharp X-figured front end! The VantommeM12 dates from early this month, please check out above link for more details. Benedict. |
(Post 3689705)
It really is not that bad my confidence lately. Their really is no hurry for it. I will wait till you do decide to come out with a puck version for now. Thanks anyways. I have tried to make the pieces for the puck conversion and it did not come out right. Plus, it took patients to deal with the grinding and cutting, which right now I have no tolerence for. I just want to blot it up setup the car and go race. I have gone back to a puck car for right now because it feels more consistant to me as of now. The tubes were getting to be a pain in the butt with popping off when i would hit a wall and get runned over becoming useless after that. Not also to mention to find the right viscosity of fluid to put in the tubes to suit my needs for the rear pod.
Orion Vortex Brushless Motors
anyone had chance to run 1 yet on 4 cell? how'd they go compared to LRP, Novak items etc ? |
I have just got my hands on an old but brand new Associated L3. Can anybody give me any tips or mods to do to this car??? I am going to run it on carpet and run 19t.
Thanks in advance |
No problem OD. I knew you were busting my chops, what chops I have left.
Originally Posted by Bryan D
(Post 3690418)
Thanks in advance Replace the motor plates with lowered ones from IRS or CRC. When the front end wears out or you break something, replace the lower arms with the new IRS lowered ones. That's it! :cool: |
Originally Posted by radio_car_racer
(Post 3690358)
anyone had chance to run 1 yet on 4 cell? how'd they go compared to LRP, Novak items etc ? //p |
| All times are GMT -7. It is currently 10:55 PM. |
