-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
AdrianM 09-06-2007 06:11 PM
TM Racing and the old Jaco rim (used on Jaco Dual Stage and TRC Capz) take unflanged.
Everything else takes flanged bearings.
jiml 09-06-2007 06:17 PM
Originally Posted by Carl Giordano (Post 3647785)
Having problems with my KO Speedo VFS perhaps a 1/12th scale master can help.
The speedo is set correctly and the punch setting are reasonable. The current limit is OFF. The problem I have is at the start of a race from a heads-up start. At the line when the buzzer goes off and I nail the throttle (i know roll-on it) the motor seems as if it stalls or just creeps off the line and once moving if fine. Problem is by this point, the guys who qualified behind me usually plow into the rear of my car or blow past me.
My lap time appear consistant once the car is moving...its just at the start of a race. Anyone running a KO VFS for 4-cell 1/12th scale you can help? Perhaps someone can provide me with the setting they use? Any advice would help?
Originally Posted by racenut123 (Post 3647796)
I have heard the Ko/Twister speedos Fets go bad or get weak after even a little use.We had someone at TCS Nats change out his speed control{vfs1 pro} to another of the same speedo{brand new} and noticed a huge difference in performance.Fets go bad.Hopefully this is not the case for you but you never know.
Carl, definitely sounds like a transistor went bad. The motor pulls the most current from a standing start. When working properly the SC will handle the current, but if one or more FET is bad it's like having a current limiter (more like a big resistor in series). Once you get going it's not as bad, but I bet you're missing some punch out of the corners.
Arn0 09-06-2007 06:20 PM
Originally Posted by haagar (Post 3648727)
The older, smaller CRC wheels are unflanged. The newest high roller wheels (procuts) from CRC are flanged (some of the older highroller wheels take unflanged).
Jaco's new Prism wheels take flanged bearings. I am not sure about the older Jaco wheels.
Thanks for the quick answers!
The old JACO rims are those ones I guess - found the picture after asking, sorry :sweat:
http://www2.gpmd.com/image/j/jacc2325.jpg
Is the choice of front Purple and rear Gray relevant? Don't know yet exactly where I will practice!!
Grenade10 09-06-2007 08:25 PM
It's about time to build my 1/12 scale for the up coming season. I'm looking for a good way to balance the weight left to right. I have the Hudy pins, but beleive there is some friction that makes the reading off.
Does anyone have a bearing set up to do this??
AdrianM 09-06-2007 08:26 PM
If you run stock get double pink fronts and grey rears.
If you will be running the new Jaco Prisms try Lilac fronts (a little harder than Dbl Pink but softer than Purple) and Yellow Rears (a little softer than Grey).
Arn0 09-06-2007 08:45 PM
Definitively stock to make sure to understand everything
Prims seems to have larger rim diameter than old school rim, no? And don't fit with unflanged bearing, so it's done!
Thanks Adrian, Haagar and all others for the details
InspGadgt 09-06-2007 08:48 PM
Have you looked at the IRS Balance Buttons yet?
Maxxratter 09-06-2007 08:50 PM
Brushless Motor in 3.2R rear pod question, really tight
Hi guys,
Question for someone who may know...
I have a crc 3.2R and recently put a 13.5 brushless in it. I'm having some difficulty with the motor tabs knocking off my damper tube, and there is not much room to adjust gear mesh, it is so close...I'm running an 88 spur and I think a 40 pinion, but it is tight...Any body have any ideas how to give me some more room? Are there different pods out there that would move the motor back a little? Smaller spurs (but how small is too small?)...
Any help and advice is appreciated.
Thanks....
BlackedOutREVO 09-06-2007 08:53 PM
Originally Posted by Scott B (Post 3648688)
OK OD, with Stockton going with B/L classes what rollout for the 10.5 and 13.5's??? Also what spurs do I need to get since I think it will be a HI rollout?:confused:
Is it October 27th yet!!!:D:D
Hey Scotty
What tires for stockton?
Probably 19 turn?
InspGadgt 09-06-2007 08:55 PM
If you have room under the body it will probably be better to run the motor so the tabs stick up through the top of the rear pod. That way they don't contact the damper tubes. Only way really to get more room is a smaller spur or pinion.
joey 09-06-2007 08:56 PM
Originally Posted by Maxxratter (Post 3649238)
Hi guys,
Thanks....
try out this spur i have one in my DB12R it will allow you to run a smaller pinion so you will have more room.
http://www.horizonhobby.com/Products...ProdID=RRP4181
AdrianM 09-06-2007 09:26 PM
That will get you into the 50T pinions on a DB12R:eek:. We know you can fit a 88/45 gear with no problem on the stock kit.
odpurple 09-06-2007 09:30 PM
The last time we ran BL at Stockton was for the NWCC. For 13.5 63mm is a good place to start, I think that is conservative. I know Ashby tried as high as 71 or something. For that race we ran 57mm for the 4300/10.5. All these rollouts were with sintered rotors :cool:
We ran PRS 88t spurs, but now they make smaller ones of you want more room (88 is perfect IMO)
Can't wait! :D
BlackedOutREVO 09-06-2007 09:38 PM
Can't wait! :D
I use Orion motors.....So the FDR is different I belive
Whats the FDR of those roll outs? I still dont know roll out like I do FDR lol.....:rolleyes:
odpurple 09-06-2007 09:46 PM
I haven't tried them yet but the IRS balance buttons look like a great way to go. BTW, the latest OD12 chassis are drilled to use the buttons.
I use a custom set up built by Chris Rhodes that works really well, the advantage being that the car does not fall side to side but just sits level while you move the parts around until the pointer is centered. Building something like this is probably more than most racers would want to do, but this thing rocks! :nod:
