Like Tree2991Likes
1/12 forum
Old 10-07-2006 | 12:59 PM
  #21106
Switch Blade's Avatar
Im going to order a corally sp12x soon and was wondering if anyone could help with the corally tyre ratings. I know where purple and pink fall in line but maybe someone could list a soft to hard list of where their gold and silver compounds come into play.
thanks
Switch Blade is offline
Old 10-07-2006 | 01:11 PM
  #21107
Thraex's Avatar
About the Corally tires,
Partnr.(tires only)-colour - shore rating.
Front Tires
1418-Goldstar - 30
1412-Green - 32
1419-Silverstar - 34
1416-Gold - 36
1417-Silver - 38
Rear Tires
1406-Gold - 28 (slightly softer than green)
1402-Green - 28
1405-Orange (Outdoor Compound)- 28
1407-Silver - 30 (slightly softer than pink)
1408-Pink - 30
Standard setup: Silver front, Gold rear.
Thraex is offline
Old 10-07-2006 | 04:37 PM
  #21108
David Galdo's Avatar
Originally Posted by FT_TC3Racer
Has anyone had a chance to try the new Epic Roar X in their 12th scale. I noticed one of the motor guys said it would be good for 1/12th scale. Just trying to figure if I should try it or keep running CO27's
If you are referring to the X-Stock (black can) then I would highly recommend it. It has torque and RPM. Very fast motors!
David Galdo is offline
Old 10-07-2006 | 04:52 PM
  #21109
JayBee's Avatar
Question guys-
I've never ran a 1/12 on carpet but planning on it for a big local race coming up. With the Checkpoint $$ motor w/Infinity brushes & gold springs AND 1.75" tyres, what rollout is good to start with? The track is small-n-tight...
JayBee is offline
Old 10-07-2006 | 09:32 PM
  #21110
thanks a lot.
For mod I liked double pink pinks from jaco, so the closest would be pink and the silver stars.
now the only thing i need is the corally tire truer adaptor
One more question, how low can tires be run down to with the pod plates on the sp12x? For mod I like to run around 47mm, so Im assuming they can run at least that low, but for stock I run like 43mm. Is it possible to go that low?
Old 10-07-2006 | 09:57 PM
  #21111
theisgroup's Avatar
Originally Posted by Switch Blade
thanks a lot.
i have a corally arbor for 1/12 if you need one.
theisgroup is offline
Old 10-07-2006 | 10:25 PM
  #21112
Mike D's Avatar
Originally Posted by rayhuang
also-just FYI-these new D-style diff rings are the best I and others (chicky) have ever used. No sanding to eliminate runout. VERY flat rings from IRS.
We developed a few design interations and worked with the shop to create a manufacturable design. Standard manufacturing flatness tolerances are less then ideal. I think the final part speaks for itself.
Mike D is offline
Old 10-07-2006 | 11:23 PM
  #21113
I've got a new JR Z3650 in my CRC 3.2r and it's making a lot of noise when I turn the power on. Any idea if something is wrong with it, or is it normal?
og_capone is offline
Old 10-07-2006 | 11:26 PM
  #21114
JayBee's Avatar
Originally Posted by JayBee
Question guys-
ANY idea guys??
JayBee is offline
Old 10-08-2006 | 01:25 AM
  #21115
Thraex's Avatar
I don't own the 12X, I ran a 12M.
But when I saw the prototype early this year, I saw the axle heights weren't changed. And for as far as I know they didn't changed the podplates in the production version.
With the 12M I drove with the stock spur gear (78t, 48 pitch) which has a diameter of 42.3mm, so I used the tires untill they hitted the 43mm in diameter.
With that diameter I could get the right ride height, hopes this helps.
Thraex is offline
Old 10-08-2006 | 02:34 AM
  #21116
corallyman's Avatar
Default Diff Rings
Hey Mike D,
Which side of the rings is the recommended side to put up against the diff balls? Is it the flat side like normal.
Thanks,
Steve
corallyman is offline
Old 10-08-2006 | 03:20 AM
  #21117
GrandeGixxer's Avatar
On this aforementioned X-motor, what is a good spring/brush combo for the beast?
GrandeGixxer is offline
Old 10-08-2006 | 11:22 AM
  #21118
mike ivy's Avatar
Hey GrandeGixxer,
I would try the F-Brush with a Red on the Pos + and a green on the Neg - or you can try a green + and Green - a close second brush choice would be a Trinity 4503 brush
Hope this helps
mike ivy is offline
Old 10-08-2006 | 11:40 AM
  #21119
Each motor is different so try different settings. I currently use black on + and red on -. I managed to get my hands on a great batch of f-brushes!
Old 10-08-2006 | 01:56 PM
  #21120
Customworksking's Avatar
Default motor
I tried on the co27 green/green reedy 769 on the dyno it was ok on the track fast!!!!
Customworksking is offline
