Like Tree2991Likes
1/12 forum
Old 10-03-2006 | 01:06 PM
  #21001
GrandeGixxer's Avatar
Originally Posted by Solara
Just couple question about the 12L4, indoor carpet and stock motor
(1) Running stock (monster or Co27) w/96 spur....what is a good ball park rollout?
(2) Tires diameter F or R...? (that will be reference to the above roll out..)
(3) Tires...I know it is very much standard front PURPLE rear GREY...but I am wonder, is PARMA front purple = Jaco front purple? Vise Versa...Parma rear grey = Jaco rear grey...? or what shores should I use for JACO.. (I already know about PARMA)
Thanks in advance.....
Howard, I got some tires for you to try out. I will even put a fresh cut on them for you.
GrandeGixxer is offline
Old 10-03-2006 | 03:28 PM
  #21002
Grenade10's Avatar
Scottrick - Great purchas on the Unity Tweak/set up. I've owned mine for 15+ years and it is still dead on. When I started racing again a few years back, I could never get to it, as it was being used. Now there are 2 new ones as well, and since the new ones have a better scale for degree's that what get used!
To the rest, I saw the post for the 13.5 being faster than stock motors. Our series is based on 19 turns, and we have 1 or 2 that have asked about the 4300 brushless. As I have one, I really think it is faster than a brushed 19 turn, but whats anyone's thought???
Grenade10 is offline
Old 10-03-2006 | 04:04 PM
  #21003
hey od thanks for the pics looks great how do you think it would do now a days.
bugsee2 is offline
Old 10-03-2006 | 04:05 PM
  #21004
Originally Posted by SpeedMerchant
HI Guys,
Hope all you 12th scalers are doing great.
Just figured I would post some info here since it seems to be the most active 12th forum on the net.
At the Vegas race, I talked to Anderson from JR/Horizon about the 3550 servo that was discontinued. I explained to him that we thought it was a really good product for 12th stock, and were unhappy to see it go away.
Long story short.
Anderson e-mailed me this morning that they(Horizon) have decided to "reactivate" the 3550 servo.
Take care.-Bruce
Ok, Mr. Carbone!
I just went to the Horizon website and they still list the 3550 servo although it does say back ordered. I went ahead and placed an order for six (6) servos to let Horizon know that there is still interest in this servo. I think OD did the same. Now, since you opened this can of worms, you had better bug Anderson a couple of times a month about following through with the reintroduction of the JR 3550 servo.
Seriously, thanks for all of your support, Bruce. We racers really appreciate all that you do for the sport/hobby.
Crashby is offline
Old 10-03-2006 | 04:06 PM
  #21005
Anthony.L's Avatar
The 3650 has been on backorder for months, did they stop production of both?
Anthony.L is offline
Old 10-03-2006 | 08:12 PM
  #21006
xtrememadness's Avatar
the 3650 is rated at .09 sec @6.0v. but can you use it without a seperate reciever pack. will it be slower running off the 4 cell pack? reason i ask is on mike dumas speedmerchant from vegas he does not run a reciever pack with this servo. thanx
xtrememadness is offline
Old 10-04-2006 | 08:43 AM
  #21007
Customworksking's Avatar
Default car/cars
what car would be best for stock indoor cefx,slapmaster,speedmerchant,crc,AE I'm having a hARDtime picking
Customworksking is offline
Old 10-04-2006 | 09:40 AM
  #21008
Jon Kerr's Avatar
Originally Posted by Randy Caster
So I did a little research on the cars, and have pretty much changed my mind to the Speedmerchant Rev 4.5. I like the lower CG rear pod, and the narrower chassis on the 4.5 over the 3.2R. Is Speedmerchant the only place to get the car or is it carried elsewhere for lower prices?
I'm looking into a 4.5 too. Is it easier to just order the car and parts from Speedmerchant direct or are there better sources? Also, with the high voltage of the 4200 cells, is a Rx pack still an absolute necessity? Also, what bodies are the most common? I've never run 1/12 scale and hate being the noob asking dumb ass questions, but...
Jon Kerr is offline
Old 10-04-2006 | 09:49 AM
  #21009
dr_hfuhuhurr's Avatar
AdrianM said it best: Find a car you think looks cool and run it.
They all are fine. The Speedmerchant is the frontrunner for link cars. The t-bar cars are all good, 12L4, Hyperform, BMI, etc.
dr_hfuhuhurr is offline
Old 10-04-2006 | 09:57 AM
  #21010
rayhuang's Avatar
CRC is about to revolutionize 12th scale building when it releases its new front end. if you search through rc.50.com youll find pics. No more black magic (my specialty-ho hum) to get a perfect front end everytime.
some highlights include super fast and easy camber adjust with pillow ball, fast caster adjustments and no more shims on the kingpins. YOu adjust spring tension (preload or no preload) with a hex driver. Very hard to build it wrong (ie. binding). Ride height adjustment will be enough to run a rim with felt on it to a full size uncut tire. Steering arm (spindle) is now outside of the rim.
Also-with the flip of a part-you can go from unheard of caster to the caster we run now as well as choosing between 0,5 and 10 deg mounts.
rayhuang is offline
Old 10-04-2006 | 09:59 AM
  #21011
timmay70's Avatar
If your local shop doesn't carry Speed Merchant, perhaps ordering direct is the best way. This way you can also talk to Bruce about set-up and taylor things to your local track(s). If your running 19t or stock, I don't think that the Rx pack is necessary. I was able to run the Spektrum with their cap and a QC2 (low bec voltage) and get away with it. For mod, people still seem to run the Rx pack.
timmay70 is offline
Old 10-04-2006 | 10:02 AM
  #21012
rayhuang's Avatar
CRC front end
I also forgot to mention that it has a way of building it to its like the old skool front end (no reactive caster or adjustable upper arm). I forget how-but Frank told me about that feature at vegas.
rayhuang is offline
Old 10-04-2006 | 10:06 AM
  #21013
smyka's Avatar
JON hopefully i can help you here most of the stock racers and mod racers(dumas,mcmahone,dayger,prichard)have all gone back to spring cars for mod so their is really only two choices rev4.5 or crc knife as for reciever packs alot of people dont run them anymore due to the new cells having so much run time you really dont get into the lower voltage of a pack to make the servo got a littel nuts on you and as for bodies it still looks like the parma speed 8 is the stock body while the protoform speed12 is the mod choice ..
ray that front end is pretty bad a$$ hopefully it will be on my car before the holloween race
smyka is offline
  #21014
Mason's Avatar
the BMI allows you to run a damper disc or damper tube setup. You get 2 upper pod plates (one for each). just make sure to understand that all the holes for the tube mounts are drilled to be tapped 4-40. i didn't know there were tubes designed to accommodate 4-40 cups. so jason is taking care of me and some 2-56 holes. the other nice thing about it is the cut on the bottom side of the chassis that recesses enough for tape so it isn't exposed as much (nor are the batteries).
great service.
Mason is offline
Old 10-04-2006 | 10:09 AM
  #21015
Looks and sounds sweet!
