-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
ThrottleControl 05-30-2006 08:31 PM
Thanks for the info, they dont sound all that expensive, I'll just need to learn to use them. Cool body, thats like the one that came on my carpet knife, big bubble!
Now what about the pinion gap, is the way I'm setting it good?
odpurple 05-30-2006 08:35 PM
Yes, hardly any gap at all.
Tim W. 05-30-2006 08:36 PM
Heres my crc 3.1 with vintage front body mounts :D
http://i73.photobucket.com/albums/i234/bk2racer/12.jpg
odpurple 05-30-2006 08:39 PM
we never used to use the white stuff without dying it first! ;)
DPowell 05-30-2006 08:42 PM
Originally Posted by odpurple
Mason,
I'll see your Lowla and raise you a 12L3 with Protoform Intrepid! :D
Check out the Dialed Racing Products sticker. Now, that is old school!! :nod:
Decathalon 05-31-2006 01:41 AM
Old School Associated 1:12 body
4 Attachment(s)
Speaking of Old School, here's my Associated Ferrari 312P. Body actually had 1978 stamped on it! Thanks Brad for the retro body...
Hicksey 05-31-2006 03:39 AM
What is the best 1/12 scale car now. I know of a couplr of brands like corally & team associated. But am not familiar with CRC is it.
protc3 05-31-2006 04:04 AM
they are all very good and are all very capable of winning races.it comes down to what you like really.
nashrcracer 05-31-2006 11:08 AM
all I got is a tamyia 956 porsche and a toj and an "I" car
http://ww.nashrcracer.com/fortheloveof12scale.htm
smojoe 05-31-2006 02:05 PM
this are regarding Niftech products
What balls fit the dynamic strut front end; 1003-01 or 1003-02?
are the Super Precision Front Suspension Arms worth the $15? (part #1003)
Mark Payne 05-31-2006 04:12 PM
Diff Build Notes
Hi all
I have just added some general diff build notes to www.12thrc.com
See what you think.
Regards
Mark Payne
RaceBucks 05-31-2006 07:10 PM
* I took a couple days off work and finally got to drive my L4 that I'd built last month - 1/12 pan cars can be squirley, but once I learned how to go easy on the throttle movements it has been a lot of fun!
* Special thanks to Lee Cauldwell and Dennis Lyman for their help in tuning the car.
Question #1: What is the best way to keep traction up for 5 minutes or more? I've been putting a lot of Paragon on my tires and letting them soak in (running purple front / pink rear on asphalt) and the grip is great for a couple minutes, then the sliding takes over.
Question #2: some people have said that they used to use suntan location for grip, is this old school or still a good way to go? or are they messing with me? :blush:
Thanks,
12ths are a lot of fun, and I can see it will make me a better driver.
odpurple 05-31-2006 07:25 PM
Thanks,
If you are running the car on an un-prepared surface, it may be difficult to maintain traction for a full 8. Paragon is usually good on asphalt but not always, try Niftech or Zip Grip, too.
Paragon or wintergreen oil and suntan lotion is still a good treatment on some tracks. Put the Paragon on and let it soak in a little then put on the suntan oil and let it dry for about 40 min (I like to put it in the sun), then wipe it off and massage in.
Every track is a little different, you need to experiment to find what works best.
AdrianM 05-31-2006 08:16 PM
Like OD said...
Black Paragon for 15 min, runny cheap suntan lotion for 30 min. Wipe it off really throughly 5 min before you race. You will have traction until your batts dump (longer than 8 min).
Pro ten Holland 05-31-2006 09:34 PM
try a lighter weight center shock oil. this usually cures that problem
