-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Mike Schumacher 03-16-2006 06:53 AM
A sweet ride! :nod: Conversion or full kit? Price?
DPowell 03-16-2006 06:55 AM
Conversion. E-mail or PM for more info.
Mike Schumacher 03-16-2006 07:05 AM
YGPM :cool:
Mark Stiles 03-16-2006 08:20 AM
Originally Posted by fast-ho-cars
you were told wrong, YRX-12 cells are in the chassis vertically. chassis with the same cell config and hole layout patterns are the CRC T-Fource, and Quad-12.
AE 12L3 chassis has 6 battery slots and 4 cells are run in the aft 4 slots. cells are horizontly mounted. AE 12L4 has only 4 slots, cells are in the chassis same as 12L3.
same cell config as the YRX but different hole pattern for items like the cross brace. you can also get a complete conversion kits like the IRS Rugrat, Hyperform H-12, BMI-12 has own podplates,
Over here in the UK, before the L4 was released, several drivers had 4-cell chassis' made for the L3. They were identical to the 6-cell chassis, except there were only 4 holes for the cells, and these were 5mm further forward than the rear holes on the std L3 chassis. It seemed to work well, and it just so happens that the cell positions on the L4 (when cells are in forward position) are the same as described above!
I can't see it being worth it now that the L4 is out, though; just buy an L4 chassis! :)
AdrianM 03-16-2006 01:20 PM
I just paid for my PRC Carpet Burn...Lets see if I can make it into a Road Rash for asphalt...lol!
axle182 03-16-2006 01:30 PM
Just wanted to send a quick thankyou to the guys who posted up their wiring arrangements. ill post mine up soon, probably after the weekend (big race meet), i bought some 16g wire, rerouted centrally under the pack, and looped onto the motor, and has significantly better pod movement. I was trueing my race motor, so threw in an old TC motor, threw a little charge into a pack, and put it on the track, was 1000 times easier to drive. Centralising of the wire weight, also keeping it low, and no more pod tweaking, the car was on rails. Im running it in stock, so its probably going to make the 8 mins very boring :D thanks
Manning 03-16-2006 04:35 PM
Manning/R66 Rcwy?
i see your in this forum
Yessir.....lurked around here for a couple of years.....
So what is the Rug Burn......a "O" or "D" plate car? :p
Looks like the best of both worlds to me, the simple battery arrangement of the link cars, with the simplicity of a "T" plate car........Very cool.
Ntensweapon 03-16-2006 06:14 PM
very nice doug!! :nod: that car would work great with a Giantkiller front end on it. :tire: :tire:
you have any super close ups of the pod/plate design? send them if you do.
you have my addy.
JayBee 03-16-2006 09:51 PM
That new Corally don't look to be too shabby either :sneaky:
nashrcracer 03-16-2006 11:10 PM
wild 12th scale from the Roar Nats discuss amoungst yoursleves.
http://www.rc50.com/modules.php?name...cat=-25&pos=46
elvo 03-17-2006 06:23 AM
I call it a "flex plate car" :D
radio_car_racer 03-17-2006 06:31 AM
show us a pic of the Giantkiller front end
CBear3 03-17-2006 08:08 AM
Maybe here:
http://www.rc50.com/modules/coppermi...r/PICT2238.JPG
AdrianM 03-17-2006 08:51 AM
Thats just an Associated front suspension with CRC upper arms.
rayhuang 03-17-2006 09:02 AM
Yeah-what a wild ride. To address the link cars issue of popping shocks aprt-he has a limiter with a stiff spring as well. INstead of side springs, he runs an anti-roll bar system. I wonder what he achieves with the long side links? When the car rolls inot a corner-do the long links apply pressure on the chassis further forward?
It also appears the rear pod is attcahed to the chassis with that monoblock thing...I wonder if its a ball and socket dealio or what?
Only thing left is-how does it work???
