Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 05-23-2006, 06:31 AM
  #14806
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by AdrianM
John - I'd like to know who makes that heatsink too.
it looks like the 3racing heatsink with the fan moved over to the side, Adrian I have one if you want it!
Marcos.J is offline
Old 05-23-2006, 06:41 AM
  #14807
fast track's Avatar
hey Adrian,
if its 3 racing I have those and the novak fan
but the heatsink looks more like the integy and we have those also
fast track is offline
Old 05-23-2006, 07:34 AM
  #14808
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Weylin: 1.21+ with IR @ 1.6 to 1.7
Thanks guys. Wait until you see Donny's "Stealthmacher" That thing looks dialed.
The heat sink is the 3 Racing. Integy has the exact same thing too. The way they come has the fan directly over the heat sink and the fan pulling air off of it. I think blowing air on the com and brushes will do more good than drawing heat off the can. So I moved the fan out over the endbell and flipped it so it blew air down. The fan is the Novak 25mm. The stock ones that come with the heat sink sometimes burn up pretty quickly when they're wired straight into the battery terminals on the ESC through a switch.
bob33: Those are actually the Losi collars from the JrXS. Perfect fit with an o-ring and they match the shock bodies.
Jon Kerr is offline
Old 05-23-2006, 08:35 AM
  #14809
ground-round's Avatar
Trader Rating: 22 (96%+)
Originally Posted by rcdougie
Adrain, Can you post or pm the setup that the team was using at the MDI race?? Thanks a bunch.
Stock A-main win -
Box stock setup with the following changes: X-ray white springs (17.5 lbs) all the way around. 50wt oil in the front. Rear Camber links in the upper hole on the shock tower. Ride height 5.5 mm. Final ratio was 6.33 with a Cobalt stocker.
ground-round is offline
Old 05-23-2006, 09:53 AM
  #14810
fast track's Avatar
Originally Posted by ground-round
Stock A-main win -
great job Jeff..... I am glad that car works for you well.
Old 05-23-2006, 09:54 AM
  #14811
fast track's Avatar
hey Adrian I have both of the fan and heatsink in stock if you want one just call tim...
Old 05-23-2006, 10:00 AM
  #14812
thanks jon
bob33 is offline
Old 05-23-2006, 10:09 AM
  #14813
Jon Kerr's Avatar
Originally Posted by aus jd 2703
and my car is still wandering can figure it out
What all have you changed?
Jon Kerr is offline
Old 05-23-2006, 10:32 AM
  #14814
STLNLST's Avatar
Trader Rating: 32 (100%+)
DADDY WILL BE COMING IN THE MORNING....
STLNLST is offline
Old 05-23-2006, 11:01 AM
  #14815
tonyp126's Avatar
Stock A-main win -
Nice win Jeff! Way to go!
tonyp126 is offline
Old 05-23-2006, 11:15 AM
  #14816
tonyp126's Avatar
Oh yeah, and congrats to Troy too....Turbodog was dialed all weekend, and I believe his car was box stock!
tonyp126 is offline
Old 05-23-2006, 02:09 PM
  #14817
mini-dub's Avatar
Trader Rating: 16 (100%+)
edit: this is fartwright on Weylin's profile and I'm fat
mini-dub is offline
Old 05-23-2006, 02:30 PM
  #14818
DavidAlford's Avatar
Wow....
DavidAlford is offline
Old 05-23-2006, 02:31 PM
  #14819
Kevin K's Avatar
Originally Posted by mini-dub
I really hope I get to share a bed with paul so we can spoon..
How long until that spoon becomes a fork??????
Kevin K is offline
Old 05-23-2006, 02:40 PM
  #14820
mini-dub's Avatar
awww shoot I knew I should have logged off of Andrew's computer..... .
mini-dub is offline
