Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 01-31-2006, 08:58 AM
  #13216
Is buggy grip still available?? I ask, as i tried to get some of that over here a while back to be told it wasn't available.
Yeah Tweak is really king over, but i guess we need to try and get some DIP over to try.
MattW is offline
Old 01-31-2006, 09:13 AM
  #13217
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Oh yeah. Stormer Hobbies has it, Tower probably has it. I get it at the local off road track. They stock it too.
Jon Kerr is offline
Old 01-31-2006, 09:35 AM
  #13218
The Teacher's Avatar
Trader Rating: 62 (100%+)
PW, I see on Fernando's setup he spaced the shock tower forward 3mm what does this do???
The Teacher is offline
Old 01-31-2006, 09:47 AM
  #13219
Trader Rating: 22 (100%+)
Teacher that was going to be my next question.
Bob Barry is offline
Old 01-31-2006, 09:54 AM
  #13220
AdrianM's Avatar
Fernando is big on keeping the camber links perpendicular to the center of the chassis. Tower spacing varies with lower arm position. I am not sure if this effects handling as other cars have pretty extreme upper link angles and they run fine.... but it can't hurt.
AdrianM is offline
Old 01-31-2006, 09:59 AM
  #13221
AdrianM's Avatar
Stomer Hobbies also has Mi2 EC and Foam Spec kits in stock
AdrianM is offline
Old 01-31-2006, 12:19 PM
  #13222
schreff's Avatar
P-Dub - You got PM.
schreff is offline
Old 01-31-2006, 12:34 PM
  #13223
Jon Kerr's Avatar
I also space the shock towers to keep the camber links in line with the CVD's. If your camber links are angled forward or backward, it will effect the amount of camber gain you get as they're not traveling on the same plane as the suspension arms are.
Jon Kerr is offline
Old 01-31-2006, 12:38 PM
  #13224
John Tag's Avatar
Trader Rating: 42 (100%+)
Originally Posted by schreff
P-Dub - You got PM.
Followers...See what I started..I guess I pack baggage..
John Tag is offline
Old 01-31-2006, 12:39 PM
  #13225
schreff's Avatar
Ya, you carry baggage alright. But it's good baggage.
schreff is offline
Old 01-31-2006, 01:07 PM
  #13226
Hey, we welcome all. And Tag, I started it
Old 01-31-2006, 01:54 PM
  #13227
EC question.
I realize there are two different cars but how would the "EC Foam" car be on carpet with rubber tires?
Or is it better to just have the EC rubber tire car? Are there plans to update the Schumacher site with the new EC info? The site seems out of date and hard to navigate.
Just wondering....Kevin Kane what's up!!
Nexus is offline
Old 01-31-2006, 01:58 PM
  #13228
I would think you would want the foam car. Remember the Rubber tire car is 2mm chassis and topdeck foam car is 2.5. I personally plan on running the foam car outside as well. If I don't think it works I will just get a rubber tire car.
Old 01-31-2006, 02:56 PM
  #13229
Kevin K's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Nexus
EC question.
Nexus.....Dont you have some diapers to change or websites to build to show case the latest "Johns" the CPD picked up
I would think, just like Bob that if you are going to race rubber tire on carpet around here med-high bite I would get the foam kit and a thin upper deck and a 1 way and go from there. Im going to get a Rubber tire kit closer to summer for outside and I might play with it on carpet some....so if you get one I will be able to give you some help. Plus Shane is getting one and running rubber tire with it and I think hes getting the foam kit with the other things. Next time you get away from the new family feel free to check out my car at the track.
Kevin K is offline
Old 01-31-2006, 03:10 PM
  #13230
AdrianM's Avatar
For racing Carpet with rubber tires we are recommending the regular Mi2EC maybe with a one way.
If the bite is super high you could get the Foam Spec lower chassis and run everything else off the standard EC.
You could also run a Foam Spec top deck on the standard EC.
Both of these setups are more cost effective than converting a Foam Spec kit with EC Towers, EC Risers, EC Top deck, etc., for rubber carpet racing.
AdrianM is offline
