Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 01-17-2006, 02:27 PM
  #12871
Conrad's Avatar
On the subject of the foam car are the top link positions any lower that on the standard EC towers? Or are they just the same minus the 2mm riser plates under the diffs, just wondering....
Conrad is offline
Old 01-17-2006, 02:34 PM
  #12872
King-G's Avatar
the alloy block markings are a little confusing as they are a legacy part from the offroad car. You must install them as Bob suggested, with the letters facing downward, and the rounded sides facing away from the centre of the chassis.
also make sure the hole for the hingepin is at the top side of the block.
King-G is offline
Old 01-17-2006, 02:37 PM
  #12873
King-G's Avatar
Please note everyone: when building the kit from new
please dissasemble your CVD's lube them and use loctite on the grubscrew. If you havent yet done this please go back and do it.
They dont come lubricated, and the locking grubscrews aren't tight enough, causing the pins to work their way out.
King-G is offline
Old 01-17-2006, 03:15 PM
  #12874
yeah i fount that out lol broke 3 pins in them in 1 run sorted now tho
bob33 is offline
Old 01-17-2006, 03:25 PM
  #12875
AdrianM's Avatar
The inner camber links are higher on the Foam spec toers than on the EC tower. This compensates for the lower drive train and lowered hinge pins.
AdrianM is offline
Old 01-17-2006, 03:43 PM
  #12876
Trader Rating: 18 (100%+)
How much is this new kit ?
Roberto Falcon is offline
Old 01-17-2006, 03:48 PM
  #12877
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
I think is 419.99
Marcos.J is offline
Old 01-17-2006, 05:10 PM
  #12878
cornerspeed's Avatar
I did this on my initial build and no problems there. It definatly needs it.
cornerspeed is offline
Old 01-17-2006, 10:57 PM
  #12879
Here's the pics of my MI2EC rubber tire car.
Old 01-17-2006, 11:42 PM
  #12880
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I forgot you've got the alloy rear body mounts. You have a part number for those?
Jon Kerr is offline
Old 01-18-2006, 01:21 AM
  #12881
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Just finished building and wiring up my EC!
Can't wait to get it out on the track.....for some valuable practice and testing!!!
Sorry about the lousy photo (battery went dead in the digi!)
DirtyDog3375 is offline
Old 01-18-2006, 01:25 AM
  #12882
bender's Avatar
OMG
What happened to the Losi? How will you be Pete's buddy now
And where's the brushless eh?
Lenny, at least your still living up to your old nickname
bender is offline
Old 01-18-2006, 02:19 AM
  #12883
OMG
It's only a car, he will cope.
Didn't want to depart with it. I had to compromise the way I drive too much, so it's gooooneeeeee!
Sticks and stones will break my bones, but names will never hurt me!!!
Old 01-18-2006, 02:33 AM
  #12884
R/C Tech Elite Member
heavy's Avatar
Trader Rating: 23 (100%+)
Originally Posted by bender
OMG
Probably depends what car Pete is going to be driving
heavy is offline
Old 01-18-2006, 05:18 AM
  #12885
bit of help please. racing at don valley its on a weird flooring (indoors runing track) but i usehky have grip. anyway firsttime out with the ec and it was a pig . got it beter by the final but bit late then. i started with the std kit set up and then my final set up was:
remove the 1mm spacers from the front pivot bloks (on risers)
swap the rear 2mm spacer to a 1mm
put a .5mm ontop of the 1mm spacer of the front rear block (forgot the real name)
front spring changed to red (to try and get sum rear end grip)
front silver role bar no rear.
camber 1 front 1.5 rear
droop as teemu (std kit)
anythink els u need ?
runing vetec tyres (control)
i just need some all round grip realy can any one help me?
bob33 is offline
