Schumacher Corner
Amongst other things i've noticed that Teemu elects not to put screws on the top deck through the motor mont. Is that some sort of trick perhaps? allows more flex thus increasing grip?????
Many of us don't use those screw holes. It can make the car flex unevenly from one direction to the other because there's only screws on one side of the top deck. This way you will have even flex side to side.
jon kerr: would you know if the BMI chassis & towers could still be used with the Mi2 EC?
Believe the towers will be fine but not the chassis and top deck.
The towers will fit but the shocks will lean in more than with the EC towers and you will have to run the inner camber ballstud lower
I heard that BMI guy is a real cool guy.thats just what i heard.
you guys racing this weekend bro?i think im gonna go and try some new setups.
mi2 ec
what parts are going to be interchangeble from the old car and the new one?
i have the aluminum front knuckles and rear hub carriers, extra arms, 2 and 6 degree casterblocks, carpet shock towers, and extra rear belt.
i am going to try and sell my mi2, but i want to know what i should keep and use again.
Front & Rear arms/Steering knuckles/caster blocks/bell-cranks/Diff housings/driveshafts/rear belt/top-deck/hub bearings/out-drives/suspension mounts/ball-cups/ball-ends/sway-bars will all be updated, but the old ones should still fit in a pinch. All the geometry has been updated
Layshaft/layshaft mounts/motor mount/chassis/towers/front belt/diff pulleys/layshaft pulleys/body mounts/rear hubs/out-drive bearings/riser plates will be all new....I'm sure I missed a few
Is mine on the way yet PW?
I heard the BMI dude is kinda weird.
You get a chance to cut that stuff yet Jason?
Yeah, that BMI guy makes you wonder sometimes....Like how dare anyone think they can improve someones perfectly designed "shaft" car....LOL
ok
i guess i will just try to sell it all.
when will the new car be avalible?
[QUOTE=protc3]I heard that BMI guy is a real cool guy.thats just what i heard. [QUOTE]
Frankly I can't stand the guy
Jon...YGPM
Mo,got your stuff ready.it will go out on monday bro.
hey paul,check out my pit station im making for myself.i think im gonna pick up .2 per lap now. i will show you it completed in a week or so.its not done yet.I guess Mo is right,i am kinda wierd. All this work for a fancy car stand.
