Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-23-2005, 03:34 AM
  #11521
Kid TT, there are a few EC parts that will fit the std car. Off the top of my head i can think of shock mounts, shocks, front suspension parts.
The transmission won't fit properly.
MattW is offline
Old 10-23-2005, 03:39 AM
  #11522
rbboy's Avatar
kidtt01: you can also put the receiver on top of the steering servo if you are using a small rx... what rx are you using?
rbboy is offline
Old 10-23-2005, 07:13 AM
  #11523
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
really the transmission fit in mine
Marcos.J is offline
Old 10-23-2005, 07:39 AM
  #11524
The production EC parts will not fit the std car, the front belt will either be far too tight, or far too loose. I can't remember which it is.
MattW is offline
Old 10-23-2005, 07:42 AM
  #11525
IslandBwoy's Avatar
If you look at the stock chasis the battery slots are perfectly rectangular where as the battery slots on the teemu chasis have more shape to 'em. Also the cutout behind the motor on the stock chasis has 3 lines; one tall one medium and one small. The teemu chassis does not have that. And finally the temmu chassis should be significantly narrower than the stock chasis but thicker.
These are all according to the teemu chasis that I have. I just converted to from the teemu to the BMI chasis so i have both the stock and teemu chassis sitting right next to each other. Let me know if you still need pictures.
can someone show me a pic of the bottom plate of the teemu chassis plz. as i bought 3 chassis and in there is ment to be a teemu one but i dont know which one it is .
IslandBwoy is offline
Old 10-23-2005, 08:01 AM
  #11526
Super Moderator
Marcos.J's Avatar
I had custom belts made for it and it fits just perfect
Marcos.J is offline
Old 10-23-2005, 10:36 AM
  #11527
IslandBwoy's Avatar
hmm. NIce! I didnt know you could have custom belts made :-(
Old 10-23-2005, 11:05 AM
  #11528
Super Moderator
Marcos.J's Avatar
all you need is the pitch , amount of teeth and alot of phone calls
oh and a lot of help from a un-identified racer
Marcos.J is offline
Old 10-23-2005, 12:13 PM
  #11529
hmm, ok. So how many teeth did you end up with?? and did you have to make any other mods? I only ask because i know what the factory has done to make it all work.
MattW is offline
Old 10-23-2005, 12:16 PM
  #11530
Super Moderator
Marcos.J's Avatar
it was done by a friend and he shaved off a little here and there and the teeth count( well thats a secret)
Marcos.J is offline
Old 10-23-2005, 02:34 PM
  #11531
So, basically i was right all along then - they won't fit in a standard car
I know exactly what was done to the prototype cars - i've had 5 of them in my hands at one point or another, and i know the 2 different belt lengths that they played with - although i can't remember which one they have ended up using Oh well
MattW is offline
Old 10-23-2005, 03:07 PM
  #11532
Super Moderator
Marcos.J's Avatar
ygpm
Marcos.J is offline
Old 10-23-2005, 05:43 PM
  #11533
Trader Rating: 17 (100%+)
Will the new EC car, have one piece hinge pin mounts?
Chico is offline
Old 10-23-2005, 05:56 PM
  #11534
mini-dub's Avatar
Trader Rating: 16 (100%+)
The EC car will come with the standard optional aluminum hinge pin mounts.
mini-dub is offline
Old 10-23-2005, 06:03 PM
  #11535
Are those one piece units, or just like the one's on the MI2
Chico is offline
