Schumacher Corner
#9572
I use the method that Jon describes as it works for tyres that are of slightly different diameter. If you set if to x on a droop guage, that is fine, but if you then happen to use a tyre that is a little bigger - either because of a thicker insert or bigger wheel, you have changed your droop setting.
#9574
...those stupid snap rings out of the diffs, but they arn't very good body scissors anymore..
R
#9576
New Fusion Team pack for sale (1.181 voltage)
I am selling one of my team packs for $80. I will pay for shipping if in US. If you bought this pack on Fusion's website, it would cost you $99.99. Only respond if you are serious about owning this pack with some tremendous punch and great run time at 428-429 run time. See picture attached
#9577
If you're going to the Reedy Race, make sure you get your parts orders in soon
RP30's are also back in stock
#9578
Hi Paul... I've got your old Mission Pro that I've just started racing on carpet here in Phoenix...I'm the only Schuie guy... I was also the only Alex guy.
I've got a carpet setup sheet of of Jon Kerr, but am he was using AE springs... what Schuie springs do you recommend on carpet??
I've got them all, just trying to cut down on my test & tune time...
Thanks!
Ron
Thanks!
Ron
#9583
I think i have the one that should be the same as the schumacher one. cause theres 2 that hudy sells the one that says 0 and the one that says 20mm and i got the one that says 0 and me looking at the schumacher one they look pretty much the same exept hudy is step and schu is the slide one.
#9584
OK, I just measured mine with the Schumacher gauges. The blocks are 10mm blocks to prop the car up and the 0 on the gauge is at the same level. So with the 2mm plate in the rear and 1mm shims in the front, your measure meant should be 4.5 in the rear and 3.5 in the front. Also remember, you'll get different readings if you change the roll center riser plates. But that's where it should be on the gauge.
