Schumacher Corner
#9182
This is the standard starting team setup fpr asphalt:
http://www.gearchart.com/setup/setup...w_2004nats.pdf
Thanks to www.gearchart.com for posting it!
#9183
Tony...YGM
Sup mini-dub!!!!!!!!!!
#9184
VIRUS?
Is there a problem with the email system at schumacherusa.net? Today I received 3 emails saying that 3 different orders have shipped. But i have not ordered anything from schu for a few months (gotta love that durable mission )
#9185
Re: VIRUS?
#9186
Whats your e-mail? I will send you the setup we used on our Mission to dominate the Florida State Series
Thanks for the help
#9187
The one adrian posted i know works well. Thats what i use and superior and it was a good base when i first tried it at tq.
#9188
Hey, when you guys find a good working setup for the BMI chasis please share. I'm planning on getting me one and wouldnt mind further testing your setups ;-)
#9190
#9191
Hmm, I got an email from Schumacher USA about the Eroneous emails today at that address so it SHOULD be working. Either way feel free to send to any of the following.
[email protected]
[email protected]
[email protected]
Thanks again P.
R.
[email protected]
[email protected]
[email protected]
Thanks again P.
R.
#9193
Hey guys,
I will be getting an Mi2 in a couple of weeks, and I'm relatively new to touring cars so i've got a few questions about the car.
I have noticed on various setup sheets that some drivers either raise the plate that the suspension mounts are on or remove the plate altogether. What does raising and lowering the suspension mount height do?
I assume it changes the rate of camber change as the hub carrier is moved and it also changes the roll center but could someone explain what each change does ie: Lower mounting block = lower/higher rollcentre = X handling.
Secondly, what are differences/reasons behind running the different drive pulleys (17T & 20T). I have a lot of theories as to the effects these have but I would like to hear what everybodies experiences are with the different drive ratios.
cheers,
Jason
cheers,
Jason
#9194
Raising and lowering the suspension mounts raises and lowers the roll center. As a general rule, lowing the mount will lower the roll center and get you more grip on that end. For instance, if I needed a lot more steering going into the corner, I would lower the front suspension. If the rear is too free, I'd lower the rear. We also angle the suspension as well by using anti/pro squat in the rear and kick up/anti dive in the front. I haven't needed to use kick/anti dive yet but adding anti squat helps the car a lot if you're too free coming out of the corners on power.
Different pulleys will give slightly different drive ratios. That's it.
Hope this helps
Hope this helps
#9195
one way -> spool
Does anyone know how i can conver my one way into a spool? I would prefer stomething that is reversable but if not thats ok.
Thanks,
R.
Thanks,
R.
