Schumacher Corner
#8941
Thanks Tony
can some one answer that question about if i can use tc4/tc3 shocks on this car with out buying the lowered shock towers? What do you guys think, is it better in buying the lowered towers and buying the tamiya shocks ? but thats like almost $100 ! its like buying a new RDX again .
#8945
TC3 shocks are exactly the same length as Schumacher std ones, so they will fit straight on the std mounts. They have a little more travel than the std ones, but they are nothing special when it comes to shocks really.
They are ok, and probably have a few benefits over std ones, but i wouldn't go out and buy a set specially.
#8947
Islandbwoy, It may be as simple as replacing you spur gear. That is about the only thing that makes my car loud.
#8948
Originally posted by LoSi xXx S
i should rather go with tamiya shocks and lowered shock towers right?
#8951
LoSi xXx S:
I have XRay and AE Springs and they work fine as long as you use spacers.
I simply use 1 large spacer and that compensates for the difference
#8952
are the TRF Shocks a straight install or is any modification needed?
[edit] I'm using a Mission by the way. Will they even work on a Mission?
#8954
They will fit a mission, just need a slightly longer than std TRF bottom joint. Think i ran assiciated bottom joint from memory.
#8955
[QUOTE]Originally posted by LoSi xXx S
[B]OH! um so the good ones are good ? cause everyone at my track has the tamiya ones , does the regular shocks can i fit ae springs ?
hey i still run the regular shocks but i cut 2mm of the bottem of the shock shaft and cut the ball cup 1mm on the top to get full ride hight with the lower shock tower. I got this from mo
