Schumacher Corner
#6766
hey king g why are your bulkheads machined? is that jsut for weight? Also is that the p-dub od the teemu chassis
#6767
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by AdrianM
Teemu Lieno started it all. He wanted really short shocks on the Mi2 Prototype so he ran Tam shocks and he never changed back. The rest of the team followed. You will find that the Factory Losi Drivers (Francis, Kinwald, Hodge, etc.) and some Associated Factory drivers(Karup when he won the Euros) followed Teemu's lead and also run Tam shocks.
The Schu shocks work just as well as the Tam shocks but are a little more work to get toghter. The Tam shocks are a slap them together in 5 minutes and they are perfect type deal.
We will have some all new shocks coming this October for the Worlds. They are an all new design for us and in testing are very good. PW and AC will have some prototypes in a few weeks. If they are as good as the testing is showing you will probably see our shocks on everyone elses cars this fall
#6768
Adrian or Paul...I got the Alloy Inboard Pivot blocks (U2742) for the rear, to get the rear toe of about 2 deg...was wondering if there is a benefit to running them up front. I noticed on a pic of Paul's car he is running them front and rear. The setup sheet I got from Adrian doesnt mention them up front, but it does show the rear toe at 2 deg...
And they do look bling bling in purple....
Also, if the new shocks are going to be all that and a bag o chips, is there a waiting list??
Are the upper shock mounts I saw in the June or July Newsletter avail in the US yet?
Thanks...Mark
Thanks...Mark
#6769
Hi i was wondering what the mi2 carbon chassis is like in stock 27t racing and what aftermarket parts i should get (i know one aftermarket part, the tamiya shocks) as i'm looking to get a new car soon
Chazz
Chazz
#6770
Not really any hop-ups you NEED to get, including the Tamiya shocks. There is no performance difference and the new Schumacher shocks will be out in a couple months or so. The lowered carpet shock towers are the only things that I would say actually gives a performace upgrade. Most of the purple alloy stuff is just cool looking. The new adjustable alloy rear hubs should be pretty good though. My car is pretty much stock with the lower towers.
#6771
Chazz - You really dont need to add anything to the kit. If you gotta have the Tam Shocks then get the lower front and rear shock towers. Thats it...
Mark - The alloy blocks in the rear give you 2deg to. Up front they just look cool and thats about all they do.
No waiting list yet.
Shock mounts are on order and will be here in a couple of weeks.
#6772
Thanks Adrian...
#6776
how much does the rapida go for there?
#6777
hey guys i jsut noticed that 1 of the battery strut things was broken off after an outdoor meeting, its only on the lower cahssis and not on the tray will this casue any tweaking or other isues with the car?
#6779
John - It will have no effect on the car. The first proto of the Mi2 has just a huge rectangular hole under the tray. The spars are there to keep from breaking the outer part of the chassis if you get t-boned or slide sideways hard into something.
