Schumacher Corner
#4726
Great performance from an AXIS 2!!!
Hey guys i have been out of racing for a year now and i decided to pick up an Axis 2... People at my track told me that belt cars are not very efficent, and not fast enough to keep up against the newer shaft cars that are out...
Well i sure showed them wrong... every one was running shaft car with a 19 spec motor, but silly old me i came with a stock motor (cause i didnt know were racing 19 spec at the time)... So i was doing some set-ups and testing before my heats and amazingly i TQ for 19 spec using a stock motor and a belt driven car....
Thanks Schumacher for proving that belts cars are just as good as shaft cars. Especially when the Axis 2 is several years older then the TC3's and EVO 3... those cars are all about looks not so much in the perfromance..
#4727
Re: Great performance from an AXIS 2!!!
#4728
Its all about setup, and driving. The Axis2 can still be fairly competative, if it is setup right and given to the right driver. You can have the best car on the market, but if you cant drive it, its going to be slow. Put an averagely tuned axis2 into the hands of Kinwald, I bet he still WOOPS ass with it...
By the way, I am currently selling my Axis2. Great for a racer, or a spare parts car for a current axis2 owner (full aluminum)
http://www.rctech.net/forum/showthre...threadid=25570
#4729
Regional Moderator
I have a shaft drive car (Yok SD) and a single belt car (KX-1) and neither is going to out pace the other. Its all in the setup.
Besides, a couple guys around here showed that belt drive cars can still compete and win. They came out with those Xray T1R cars and simply amazed everyone at how fast 2 belt cars still are.
I don't really think there is any one 'right' drive system. They all seem to work pretty darned well.
#4731
Oh he!l yes! I want it! Looks awesome!
Just wondering...
Have they changed the drive pins at the hexes to prevent the occasional breakages there? And How about the way to tiny drive pin for the pulley?
If those things are fixed, and it's a step up on the Mission in the other departments, is this going to be THE perfect car?
Just wondering...
#4732
Hex drive pin - no don't think so.
Pully drive pin - not sure. Last time i saw the car it was still very much prototype on the layshaft.
#4733
Regional Moderator
Ooooooooohhhhhh, yeah! I think my interest in TC for next year might have just been sparked.
While we're on the subject of whats been fixed, will this car have one peice pulleys for the drive train, or will there still be the problem with the pulley fences falling off? Or at least will the manual clearly specify which way the fences went on.
The constant problems with the fence on the main pulley is what drove me away from my original Mission.
Any idea what the projected price will be?
#4736
I want to embrace this car, but what are the issues that have been fixed?
Apart from the small pin, I don't have a problem with the pulleys, never had a fence fall off the plastic or alloy ones in nearly 2 years. So if they haven't fixed the pin, will the car be coming with alloy pulleys?
Seeing as everyone has to buy them later, will the car be coming with RW pulleys? Doesn't look like it on the CAD.
It's hard to imagine that it can handle THAT much better than the Mission , so is the major thing that it now comes with all the alloy stuff I had to buy aftermarket. I assume it will also tweek nicely straigh out of the box now?
I don't want to bang down the mood on the new beast based on a CAD drawing, I just want to find out where the advances are, I'm a little impatient like that!
#4737
Regional Moderator
Originally posted by AdrianM
The layshaft pulley fence will never come off if its put on the right way.
Thats kinda why I mentioned the manual. Because if I recall correctly from my building the car, there were two diagrams on the page and they each showed it on in a different way. A lot of people had problems with that fence being installed incorrectly, which means that the manual could have been clearer about which way it went on. Like me, other people noticed that in one direction the pulley went on easily, in the other direction, it seemed to be to the point of breaking before it would go on. Who would expect that the later of those two was the correct way to install it?
I was just thinking of a line or two at that step, like "the tall side of the fence should be facing 'this way'(in or out) when installed correctly..." or "the pulley fence will take some force to install..." Something like those...
Just a suggestion though...
#4738
Adrian,
Do you know if the diffs will be the same as the Mission's, i.e. can I use the RW pullies/diffs from my Mission on the M12?
#4740
It looks like there are going to be some tiny improvements on the new M, but will that warrant the purchase of a whole new car? This car coming with full alluminum and threaded shocks, what is the sticker going to be? I am guessing about 325$? Will it come with a one-way?
