Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-04-2008, 04:32 AM
  #26206
hmmm thanks guys but its on the front and i like the narrow width is there any stronger options that dont increase width?
aus jd 2703 is offline
Old 06-04-2008, 06:02 AM
  #26207
theisgroup's Avatar
Originally Posted by aus jd 2703
hey guys ive been having trouble with snapping axles ive snapped 2 in very light contacts (corner dots) is there any options for stronger axles?
what could cause this? any suggestions
where are you snapping the axles? maybe post a setup
theisgroup is offline
Old 06-04-2008, 06:52 AM
  #26208
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
well you can also ream out the rim a little bit to fit the axle with out adding the extra shim in the front.
Marcos.J is offline
Old 06-04-2008, 07:14 AM
  #26209
slammin's Avatar
Trader Rating: 88 (100%+)
Originally Posted by skypilot
thanks for that.
btw, any shouie guys - driving - to pavement nationals, just a little heads up, i won't be packing any type of liquids for the flight and will be bugging you guys for hand outs, also not bringing a soldering iron. not complaining about my borrowing stuff will get you a drink, or some sort of food of your choice.
or i may just buy it at the track and give it away after the race depending on how much you drink/eat.
You can come borrow some stuff from me if need be .Since its only a 2 hour drive for me I going to pull my trailer up with me. And will I have it stocked with plenty of supplys.By the way I like Mt. Dew.
slammin is offline
Old 06-05-2008, 10:50 AM
  #26210
Super Moderator
Marcos.J's Avatar
Originally Posted by JayBee
Marcos da Prophet!!
here it is JayBee!! (thanks to fellow teammate TonyP for the picture)
Marcos.J is offline
Old 06-05-2008, 11:12 AM
  #26211
JayBee's Avatar
Trader Rating: 31 (100%+)
Thumbs up
Saweet!!
JayBee is offline
Old 06-05-2008, 04:54 PM
  #26212
redlion's Avatar
Saweet!!
+1
redlion is offline
Old 06-05-2008, 07:31 PM
  #26213
JayBee's Avatar
Hey guys real quick- When Randy Caster ran the Tamiya 414 pulley for overdrive, anyone know how he got the front belt to tighten up?
JayBee is offline
Old 06-05-2008, 07:51 PM
  #26214
Super Moderator
Marcos.J's Avatar
414 is a 32t pulley i think you will need a shorter belt like a 169t or a 167 t hpi belt to get the correct tension but thats a lot of overdrive i think he probably meant was the 415 pulley thats 35t, i think thats why Schumacher released the 35t pulley. i think a 1.6 ratio in the front is alot.
Marcos.J is offline
Old 06-05-2008, 08:15 PM
  #26215
skypilot's Avatar
Trader Rating: 14 (100%+)
you have no idea how much OT you just cost JB.
skypilot is offline
Old 06-05-2008, 08:17 PM
  #26216
skypilot's Avatar
thanks.
skypilot is offline
Old 06-05-2008, 08:20 PM
  #26217
Goingfast's Avatar
Trader Rating: 29 (100%+)
Well One teeth isn' bad compare the Losi xxx-s ,they're two teeth different over drive ...
Goingfast is offline
  #26218
Goingfast's Avatar
thanks.
Hey Richie
Are you going over to SIR tomorrow nite?
Old 06-05-2008, 08:23 PM
  #26219
Goingfast's Avatar
this set up is for the Diff or one way?
Old 06-05-2008, 08:27 PM
  #26220
skypilot's Avatar
hey franko, yea i will be at SIR around 3:30 or so, the pulley is used with the spool only i think, i've pretty much given up on using the one way.
skypilot is offline
