Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 03-28-2008, 08:50 AM
  #25606
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by DavidAlford
Are you just looking for another reason to bring the dress back out?
I dont think he needs schumacher for a reason to wear the dress
Marcos.J is offline
Old 03-28-2008, 10:33 AM
  #25607
Trader Rating: 37 (100%+)
Originally Posted by Skiddins
The packs are 8.4V maximum. 4.2V per cell.
The Core 5000 packs are two cells in series (2S) (all connected etc internally so you'll never see them.)
The balance connector has one wire connected to the same place as the positive, the middle wire connects inbetween the two cells, the third wire will go to the negative.
This middle wire allows the balancer to see the difference between the two cells as well as the overall voltage of the pack.
All lipo chargers should maintain maximum charge rate until the pack voltage reaches 8.4V, the charger will then slowly reduce the charge rate so the voltage does not go above 8.4V, this will keep reducing until the pack has finaly finished charging.
This all make sense?
Skiddins
Thank you! Yes it all makes sense now. This is a pretty cool charger...gobs of info available during the charge.
Thanks again Skiddins.
jubilee is offline
Old 03-28-2008, 11:59 AM
  #25608
still, what makes you think we even want you back on the team? lol j/k
gdcopbdcop is offline
Old 03-28-2008, 03:07 PM
  #25609
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default a
Adam guess what U have PMS oop's PM
Customworksking is offline
Old 03-29-2008, 02:40 AM
  #25610
wstuart's Avatar
Trader Rating: 117 (98%+)
2 quick questions
I just picked up an mi3 - i took the rear diff out for a rebuild and now when i put it back in - i cant quite get the rear dif to line up perfectly with the center pully. the rear diff pully is pulling the belt over to the center just a hair - just enough to make the belt rub a little on the rubber fence in the center pully and make the drive train not run as smooth. It didnt do this before i took it apart and i cant figure out how to make it smooth again
also im trying to run an orion 4800 - i heard i need new steerring linkages to clear the battery - does anyone the part number on the new linkages/ an or a good way to get a 4800 in there
wstuart is offline
Old 03-29-2008, 03:46 AM
  #25611
Ian S's Avatar
Originally Posted by wstuart
2 quick questions
Did you put the pully on the outdrives the right way round?
You need the option steering linkage to run lipo but i can't find the part number on the website, im sure someone else can point you in the right direction.
Ian S is offline
Old 03-29-2008, 04:51 AM
  #25612
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I had a 4800 Orion in my Mi3 without anything modified. It did require precise location of the battery and Ill tell you that it was not perfectly parallel with the chassis.
andrewdoherty is offline
Old 03-29-2008, 08:06 AM
  #25613
wstuart's Avatar
im think the out drives are on the right way - the female end is ont the motor side - so it puts thediff gear closer to the battery side. i even moved the fences over to try to get the belt as close to the battery side s possible
wstuart is offline
Old 03-29-2008, 05:45 PM
  #25614
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Is there really an MI3 '008 version in the works? What is being changed, revised, or improved in this updated version?
yyhayyim is offline
Old 03-29-2008, 06:30 PM
  #25615
R/C Tech Elite Member
abailey21's Avatar
You need to quit reading the National Enquirer
abailey21 is offline
Old 03-29-2008, 08:58 PM
  #25616
Big Features's Avatar
But thats where Elvis gives his yearly tax tips!
On the next page, Tupunk Shaker and The Notorious F.A.T. have decorating tips for spring
Its 1800L in Hawaii right now, and I'm half in the bag.......
Big Features is offline
Old 03-30-2008, 04:14 AM
  #25617
abailey21's Avatar
so THAT'S why they call you Big Features
Old 03-30-2008, 06:44 AM
  #25618
Ian S's Avatar
Thats not what I mean. If you rebuilt the diff then you could have put the pully on the outdrives the wrong way round but still have the outdrives on the right side. The male outdrive needs to go on to the deep side of the pully, check the manual for what i mean.
Ian S is offline
Old 03-30-2008, 11:10 AM
  #25619
Trader Rating: 90 (100%+)
I got to see Mr. Goetz in action yesterday and his Mi3 was looking most dialed.....................
Nice run CG....
RBLove is offline
Old 03-30-2008, 11:54 AM
  #25620
redlion's Avatar
Default C2
Thanks to the Schuie team. Great car and support. The car was on rails started second finished frist in the a main, at our local club race. Steve your car was looking good also.
Wes
redlion is offline
