Schumacher Corner
If Chris has a wet weather setup, I'd try it on this track.
Guys try this...Chris Ashton Tarmac Day setup in the book...then if using rubber tyres...use trinity buggy grip 2 on them with warmers
Shawn P. you got pm
Eaves: missed you this weekend - though you might have came down with the rest of your boys. Let me know how the Schui is treating you.
L8R Marker
L8R Marker
Did'nt finish the car till late friday,car was awesome myself,Hess,Endland were running good,you need to come up turnouts are pretty good
Ran my MI3 for the first time Saturday. The body didn't even get mounted until the morning time. It took a while to get used to the new car, but by main time it was fairly good. I was not the only Schumacher car there. All the guys put on a good show. If anyone needs a high bite asphalt setup, I have something that will get you close. Can't wait to run it again... I was not sure if I could get away with running the low shock towers with rubber tires, but it seemed to be right on.
Super Moderator
R/C Tech Elite Member
Or run with high droop,10mm.
I was running in low grip parking lot,lower the diff,soften the shock oil(30wt),but i run the rear diff tight,other,just follow Randy Reedy set-up.
any other suggestion for low grip and tight
Tech Legend
Trader Rating: 51 (100%+)
I posted this a while back Has anyone else ran the lowered/foam towers on rubber tire carpet ?
