Schumacher Corner
Super Moderator
Adam, I just PM'd you an order for a few things. For some reason my Email wouldn't go through. You may get it later. Just ignore the Email.
R/C Tech Elite Member
Hey all quick update that a lot of people have been ewaiting to hear...
(U2741) 1 degree alloy rear hub carriers are back in stock!
Hey guys, I got a question about diff balls. In our diffs on the mi3 we use balls that are a lot smaller than the ones used in 12th scale cars and oval cars. I was just wondering if there was a reason for this and if anyone tried using bigger balls? Would there be an advantage?
Im guessing that if we just added the bigger balls to our diffs they wouldn't build right, but if the diff was designed for them; could there be any difference? Doubtfull, but still curious about it.
So, answer me this...
Who's got big balls?!
Schumacher ended up going with the smallest balls they could easily source in Europe...2.5mm.
3/32" (2.4mm) balls from associated will not fit. The width of the center of our diff pulley is designed to let a little of a 2.5mm ball peek out either side. With a 2.4mm ball the diff rings will be too close to the center of the diff pulley and that messes everything up.
That said there is no reason to run anything over than U2459 T/C diff balls. They are THE BEST. Over the last 6 years that I worked at Schumacher we tried every kind of diff ball from every place you can imagine and nothing worked as well as out tungsten carbide 2.5mm balls.
I think ceramics have a lower coefficient of friction against the steel rings than tungsten balls. As a result ceramics tend to slip easier and this chews up diff rings faster.
Roll Call who going to MINNREG this weekend I'm in for 10.5 rubber
Back in the day...the SST series sedans had 4mm diff balls...thats really big. In testing Schumacher R&D found that smaller diff balls gave a diff more limited slip action. This means is you ever lift a rear wheel smaller diff balls send more power to the wheel on the ground than big diff balls. Thats a good thing.
Cool.... thanks!
Thanx Adrian
I've just checked p-dub website and There is nothing on sale so where you guys bought your p-dub bumpers
@Adam
You've got PM mate
You've got PM mate
Super Moderator
