Schumacher Corner
#2236
Something with every diff is you can flip the rings around and try to "buff" the rings with 600 grit sand paper to get rid of high spots. I think your problem have to do with you built it wrong or something is wrong with you thrust balls or rings. Check it agian for any of this.
Hope this helps
Hope this helps
#2237
Rob,
Sorry about the confusion. Blonde hair, hang out with Lafara and Starkey. Ring any bells now? I didn't think Puffy ran gas, I knew Eli did. I'm trying to get into the Worlds over there so I'll be over your way sooner or later. How about some directions to the track?
Thanks,
Socko
Thanks,
Socko
#2238
I'm not talking about the carbide ball rings, but the thrust washers. They have grooves in them. I'm not sure if they come with groves or they were worn in ?? Looked like they came with grooves in them.
#2239
I am not familiar with mission diffs but on all other cars they are supposed to be flat flip them over and see if the side has to wera on it and use that. I am sure all these guys will give you all the help you need.
#2240
Regional Moderator
JonB: I know where your coming from. I don't think the Schumacher diffs will ever get that silky smooth, smooth as glass feeling that the TC3 and XXX-S diffs have. At least none of mine ever have. From original SSt2000 to the now Mission, the Schumacher diffs I have had, have never gotten that feeling. THey always seem a little gritty. But they work well.
#2241
alright, that's what I thought.
#2242
rear arm position
Hey guys, I was looking at my car last night and I noticed something odd. The distance from my right shock ballcup to the rear turnbuckle is about 1mm shorter than the left side. If you look at the car it seems like the left-rear arm is more forward than the right. This is no optical illusion either, I measured it. I am running the 2* blocks on both sides, and checked to make sure that everything is exactly the same on both sides. I looked at Pat McCarson's car and his is the same way.
When I was running at Ripon the other night my car had way more steering to the right than to the left. All of my steering links are measured and exactly the same, so I'm thinking this could be it. If the left-rear arm is more forward than the right, it would cause the car to want to turn harder right (theoretically). If this is built into the design of the car, I'd like to know why...I'm curious.
#2243
is your steering epa set right? set it so you can do circles in both directions equaly.
#2244
the car should turn equally both directions already...unless it was designed this way. I'm looking for input from someone from Schumacher perhaps.
#2245
ko propo fet 947 fet micro servo
In a past rc car action....they were testing the mission and they used a ko pds 947 mini servo. is this possible?
thanks,
richard
thanks,
richard
#2247
Diffs
The thrust race is supposed to have the grooved washers, they help spread the load.
Personally i have been very happy with my mission diffs. I have been able to get them feeling better than any other previous schumacher diffs. I have been buffing the main plates with 600grit before i built them though. I also used AE Black/stealth greese.
Not sure about your problem with rear arms. My car is in bits at the moment so i can't check it.
#2248
S1 Mission
Hey guys, long time viewer here, first time poster. (that sounds pretty bad!?!) Just wanted to let you guys know I'm gonna try out the S1 mission and see how well it works compared to my graphite mission. I regularly run at Ripon R/C speedway (high traction track) and Castle Hobbies (mid to high traction). I'll report back soon and let you guys know what happens! Good luck racing!
#2249
WOW, I have 2 other posts, I guess I'm not an R/C Tech virgin!
#2250
Socko, I think I know who this is. If it is the guy I am thinking of. Ask Skip about those ballcups He'll know. Tell him Rob said to ask.... I do not know how to get to the track from 70. Your best bet would probably be to use Yahoo Maps. It is on Route 4 off of 275, but I am sure you can get there from 70.
Sigearhead, Hook Socko up with some directions to Ultra.
Will be testing the roll center mod and kick up on carpet this weekend with foams. Also testing some new foams. I will post results here Monday or Tuesday.........
