Schumacher Corner
I would take 1mm of Droop out of the rear and lower the rear roll-center by .5
That should give you more "off power" grip.
setup
I ran jimmys setup and found it to be way to loose in med bite track.Also the rps are smaller than the jacos so you have to change the droop.The changes i made were going back to the standard hole on the steering block ,1mm less droop in the rear and stood the rear shocks up one hole.
Schumacher MI3 is definitely the truth. With the help of team drivers Brett Sisley (DIALED) & Ritchie Reynolds (skypilot), our cars are definitely on the 'FAST' side of the tracks..........
Go Schumacher!!!
Go Schumacher!!!
Agree with you AAron Standing rear shocks 1 hole up and front shocks one hole in makes car much better...I normally set droop like 5.5mm front ,4.5mm rear
Can anyone explain what difference it makes having the steering plate in the different positions please ?
2mm shim in the front
0mm shim in the rear
1deg alum rear hubs = about 3deg
I believe this will be the same as your first example
It said somewhere that each 0.5mm shim added 0.6deg of toe, but I'm not so sure.
Skiddins
1mm shim in the rear
stock rear hubs
= how much toe = 3deg
.5mm shim in the rear
1deg alum rear hubs
= how much toe = 3.6deg'ish? :P?
I'll just use my camber gauge and hold the car upright to get an idea of degrees.
Thanks for the input.
I believe the rear of the car without shims is 4mm. So if you start adding shims or hubs with specific degree in them you can alter your toe.
2mm in front of rear bulkhead would give you 2mm toe.
Marker
Marker
Need help.
What is the name for the parts that you change to set the acramen? It goes on top of the stearing rack. Does anyone have a part #?
Pound -
Track rod set - U3135
Chris
Chris
R/C Tech Elite Member
