Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 07-09-2007, 01:17 PM
  #20686
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default MI3 ARMS
ARE THE MI3 ARMS DIFFERENT THAN THE ARMS ON THE EC?
IF SO WILL THEY FIT ON THE EC?
I DON'T REALLY WANT TO MESS WITH CAR TO MUCH. IT'S PRETTY MUCH DIALED FOR STOCK OR 19 TURN.
IT WAS JUST THOUGHT........
RED-LINE M03 is offline
Old 07-09-2007, 01:21 PM
  #20687
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
they are the same the MI3 arms has another mounting hole for the sway bar mounting since is different from the ec
and if you use the mi3 arms on the mi2 you might not be able to use sway bars
Marcos.J is offline
Old 07-09-2007, 01:25 PM
  #20688
THANKS SUCKER.............
Old 07-09-2007, 01:29 PM
  #20689
Super Moderator
Marcos.J's Avatar
no problem fool give me a call later
Marcos.J is offline
Old 07-09-2007, 01:34 PM
  #20690
R/C Tech Elite Member
heavy's Avatar
Trader Rating: 23 (100%+)
Also the Mi3 arms are narrower at the outer end where the rear upright mounts - you will loose teh wheelbase adjustment if you use them on your EC.
heavy is offline
Old 07-09-2007, 01:42 PM
  #20691
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
They're a little more reinforced too.
Jon Kerr is offline
Old 07-09-2007, 03:38 PM
  #20692
Trader Rating: 26 (100%+)
What's the best belts to use on the MI3 for mod (LRP X-11 4.5)? Do they grey belts hold up or are the standard black ones the go?
Cheers Andrew
CountryHick is offline
Old 07-09-2007, 04:03 PM
  #20693
Jon Kerr's Avatar
Cheers Andrew
Stock black belts
Jon Kerr is offline
Old 07-09-2007, 04:26 PM
  #20694
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Randy Caster
Just got done building my 5 cell car for the Nats, figured it's as clean as it'll ever be so I might as well take a couple pics before it gets packed for the trip to SIR.
Nice ride Randy C-ya when you get here....and bring some of those purple 'buckles
JayBee is offline
Old 07-09-2007, 04:45 PM
  #20695
yyhayyim's Avatar
Originally Posted by Jon Kerr
Stock black belts
my front belt is wearing twice as fast as the rear...why?
yyhayyim is offline
Old 07-09-2007, 04:51 PM
  #20696
Jon Kerr's Avatar
Make sure your set screw on the pinion can't touch the belt. When the car is running, the belts don't exactly stay in a straight line. They deflect up and down. The front belt can hit the set screw and start to wear away the teeth and make them fray sometimes.
Jon Kerr is offline
Old 07-09-2007, 07:16 PM
  #20697
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I have just enough of the purple turnbuckles to cover my cars unfortunately, I tried to order more but I cleaned Speedtech out lol.
Randy Caster is offline
Old 07-09-2007, 07:53 PM
  #20698
POUNDITRACING's Avatar
you can count on Randy to have a very hot looking car.
How do the bodies look?
POUNDITRACING is offline
Old 07-09-2007, 09:57 PM
  #20699
Lookin good, sorry I forgot to call you about them, been super busy getting the stuff ready for the race this weekend.. Thanks again Ray!
Old 07-10-2007, 02:21 AM
  #20700
Trader Rating: 19 (100%+)
Originally Posted by John_S
I got an xray 007 to try untill the mi3 came out to replace my aging mi2 ec. The first problem i had was seized bearings. The second problem i had was 2 broken bulkheads!!! i would have imagined the shock tower to break before the bulkheads at least. All in all i have never had a problem with my mi2 ec exept for the driveshaft pins but this was easily solved with steel driveshafts
ON WHICH CAR DID THE BULKHEADS BREAK
teammidget lilB is offline
