Schumacher Corner
Originally Posted by PW
1.5mm
If you use a screw, make sure its a small thread (2 or 2.5mm). Regardless of the screw size, it will make the block slightly more brittle.
Also Matt....when you mentioned lock and steering lock...? What is that..? Or do you mean steeringblock..?
Steering Lock is the amount of steering travel that you have.
were will you be able to pre order the mi3?
i hope so. im gettin one
1.5mm
I won't be drilling the C'Hub at all.
Skiddins
Tech Legend
Trader Rating: 51 (100%+)
Pretty quiet in here. Everyone must be getting ready for New Years!!!!!!!!
haha yeah, that and most of the guys are already in Wisconsin, or soon to be.
Happy New Years every one!!
can't wait to see the mi3 in action in 2007
yeh happy new year from australia, hope ya had safe holidays with ya families.
good luck for 007.
Josh P
good luck for 007.
Josh P
EC Foam Spec
Hiya
I have purchased an MI2EC Foam Spec
I am going to be racing on asphalt with foam tires, what shock setup should i use.
Should i use the 3 hole pistons that come with the kit or should i use tamiya 2 hole pistons, also what weight oil and spring combo should i use?
I will be running the novak 3.5 brushless and the standard 2.5mm chassis.
Originally Posted by MoonTrap
Hiya
If your looking for Q&A's about the new Mi3, check out the Schumacher website as PW is talking about the new car http://www.racing-cars.com/forum/forum_topics.asp?FID=2
hey guys i bought a couple mod motors to muck around with (hoping to some how improve my driving) i was just freshning up my car. new thrust bearing new belts maybe a spur(though i think its still got 90% tooth) just maintence.
what else should i prep to get ready for 8 and 9 turn motors?
also whats a soft gearing set up for:
9 single
8 single
8 double?
im not racing so id like to conserve the motor, btw they are all team orion revolution old style (not oscar johansen).
btw happy new year.
cheers, Josh P
9 single
8 single
8 double?
btw happy new year.
cheers, Josh P
Guys,
Anyone Know the length of Shumacher Front Belts? Need 171/172 teeth for my car? Or- what model has the longest belt??
Where do you guys get your parts????
Cheers
Cheers
Super Moderator
Originally Posted by beaverltd
Guys,
Cheers
Cheers
