my keeps glitching/twitching!! what do i do?
hi everyone. my car has been twitching/glitching on me when im not even that far away from it. im really close.it never did this before but one day it started to do this and ever since its beenn doing that. everything on my car is fine such as the receiver and the radio. my radio has good batteries in it and my receiver is still fine, and my crystals. some guy said that the brushless systems pulls so much battery voltage or something like that so that the receiver doesnt get enough battery to the reciever on my car. he siad that i should get a capacitor or something like that. im not to sure what that is and what it does, but he said that it would make things better. can i get some advice on what to do, and some advice whether this guy is right. thanx everyone
Is your motor cogging? Does it seem like it's stuttering rather than "glitching."
I know it sounds synonymous, but cogging is describing the motor and glitching in my definition is the radio dropping in and out of lock...
On my first brushless system, I discovered that one of my battery pack was not up to the task of sourcing enough current to the ESC and motor, which caused the car to "cog"
A capacitor might mitigate some of the problem but may not solve it. If the car glitches depending how far away you are rather than current drain (i.e. it glitches when it's just standing still) then a capacitor is not going to do anything for you and you need to check the radio rather than the BL or servo. That's where I would start. Get back with some more info and we might be able to help you.
I practically had one such case twitching. What happens the car does not goes straight. I put on on the stand. Pull the throttle to 3/4. The steering starts to twitch 2mm left right. When I happen to slow it down it twiches but lesser.
After some troubleshooting the GTB Esc seem to be the problem. I had it replaced.
You need to give more detail than that. Glitching isn't an unambiguous symptom for something or other. There can be a multitude of things. Start by explaining what BL system you use, what radio, etc.
thank you.
