Like Tree3Likes
Xray T1
Old 01-30-2005, 08:25 AM
  #11446
Default RE: Shock building
haha, I had/have the same problem. I just said screw it, filled the shocks up with oil, cycle it and let it sit for a bit, then when I'm ready to close the top cap, push the slider in a bit more than half way, then tighten the cap. Yes, it does rebound, but I don't think it's hurting my cars performance. (I might be wrong)
-Stan
skinart76 is offline
Old 01-30-2005, 08:26 AM
  #11447
Oasis's Avatar
Trader Rating: 38 (100%+)
You need to get the newer style bulkheads(the ones with the built in adjusters..cams)Thats the only way to tighten the rear belt that i know of.
Oasis is offline
Old 01-30-2005, 09:25 AM
  #11448
Scrad's Avatar
Trader Rating: 16 (100%+)
I've got a full set of the T1R bulks that are adjustable. PM me if you are interested.
Does anyone have an extra 32 tooth diff gear. I have 2 extra but they are for the spool and oneway. I need the smaller hole one to build a diff.
Scrad is offline
Old 01-30-2005, 09:29 AM
  #11449
jackhammer74's Avatar
Post RE: Shock building
You know I always heard about how the TRF shocks were the nicest ones outhere, but I guess I never really realized how nice and simple they are, until now I may just get another set of TRFs and find a way to put them on my T1, can't be that complicated.
jackhammer74 is offline
Old 01-30-2005, 01:57 PM
  #11450
rdub202's Avatar
Trader Rating: 19 (100%+)
check a few pages back maybe four or so they were talked about and how to put them on
rdub202 is offline
Old 01-30-2005, 02:10 PM
  #11451
duckman996's Avatar
Trader Rating: 14 (100%+)
Default Re: RE: Shock building
Mounting Tamiya shocks on an X-Ray is no problem at all ... there are a few posts that explain how to do it in this thread. I did the change and have had no complaints.
duckman996 is offline
Old 01-30-2005, 02:34 PM
  #11452
Post shock building
thanks guys
Old 01-30-2005, 03:29 PM
  #11453
Thraex's Avatar
Default Re: Re: RE: Shock building
Can someone explain me why you would replace Xray's shocks with the TRF ones?
I've seen them used by some drivers, but I can't figure out why they are better than the ones that Xray makes...
Thraex is offline
Old 01-30-2005, 03:38 PM
  #11454
duckman996's Avatar
Arguably, Tamiya TRF shocks are the best in the business ... smooth, easy to rebuild, and reliable. The factory X-Ray shocks are a little hard to build - it is hard to get all the air out (not impossible, but difficult).
TRF shocks seem to be more consistent - and very easy to get parts for if you need to. Example - if you wear-out the bottom ball-end on an X-Ray shock you may have a hard time finding one - on a Tamiya, pretty easy to get.
Old 01-30-2005, 03:47 PM
  #11455
FW-05RR's Avatar
hoddap was runnign the new x-ray at socal yesterday
FW-05RR is offline
Old 01-30-2005, 03:54 PM
  #11456
NVisible's Avatar
and?
NVisible is offline
Old 01-30-2005, 04:40 PM
  #11457
Yes such an informative post.
Besercoe is offline
Old 01-30-2005, 04:49 PM
  #11458
[QUOTE]Originally posted by FW05R
hoddap was runnign the new x-ray at socal yesterday [/QUOTE
Ok I give up............and........................
Ginsu is offline
Old 01-30-2005, 07:25 PM
  #11459
I was looking for some help on my fk. The car is very good. I am running on pace at my local track and the car is fast but it almost pivots mid corner. I am running Cyrul's carpet nat setup. I had another driver drive the car and he had the same feeling. It enters the corner and then almost breaks and pivots then finishes the corner. Its not really abrubt but was wondering if anyone had any suggestions?
JimMcClure is offline
Old 01-30-2005, 09:33 PM
  #11460
Awww, Crap!!! I was there yesterday also. I guess I wasn't paying attention and missed it!!!!
