Xray T1
You "might" be a bit mislead by the leaking. The lower cap gets filled with shock oil after the bleeding process and after tightening it on-the oil that has filled the cap continuously leaks out. I hate it too. Messy.
I am not 100% saying your wrong-just an observation from my own xray shock experiences. Also-replacing the black o-ring that sits on the body of the shock can be helpful too. YOurs may be worn out, cut or even missing.
Of course if you steadily loose rebound-then hear air in your shock in short order-well I'll just shut-up!!!
That, I don't know. I'll have to look around and see.
To mount the shocks, use Tamiya's mounting hardware . With that, I think it's an easy fit, IIRC.
Rob
Rob
Recently got an FK and would like to get any foam set-ups for an asphalt track. All the quick guys use 40shore fronts and 40shore rears and will also be using the same set of tires, so any help on some setups that might work for the car.
Another thing, What are the pros and cons of placing the batteries to a split position (one side is closer to the front)?
Regards,
Regards,
Xray Setup Sheet
Here's an Xray setup sheet for you guys to use...
Regards,
Regards,
Jon
Gearing
Who knows some good gears i should get for my T1R.
I have a T1R with a 2.1 internal ratios with 64 pitch gears for a Stock motor?
Jason
Jason
Re: Gearing
Jason
Jason
Trader Rating: 22 (100%+)
Originally posted by JDXray
If you have the one pair of batteries up front it would increase your steering and more grip in the front i think. Someone could double check me.
Jon
Jon
Does anyone have a good set up sheet for a T1R that would be good for outdoor racing with a Stock Motor?
white springs all around, 2* camber, 2 holes open, 3rd hole in front tower, 4th on rear, 2* toe-in, 1/2* toe-out.
That's almost my outdoor setup exactly. I run 6 degree caster blocks, as most outdoor tracks seem to be more open and flowing where you'd need more on-power steering.
Rob
Rob
I run 3* blocks, havent really had time to experiment with others.
Originally posted by Scrad
My car is handling pretty good, but it hooks in the middle of the corners. (Rotates fast). How can I fix this without changing the handling in other areas?
It would be great if you listed your setup. I run a spool & a light diff in the rear and havent had this problem.
