Old 12-06-2004, 12:56 PM   #10651
rayhuang's Avatar
You "might" be a bit mislead by the leaking. The lower cap gets filled with shock oil after the bleeding process and after tightening it on-the oil that has filled the cap continuously leaks out. I hate it too. Messy.
I am not 100% saying your wrong-just an observation from my own xray shock experiences. Also-replacing the black o-ring that sits on the body of the shock can be helpful too. YOurs may be worn out, cut or even missing.
Of course if you steadily loose rebound-then hear air in your shock in short order-well I'll just shut-up!!!
Old 12-06-2004, 01:09 PM   #10652
Rob Mincey's Avatar
That, I don't know. I'll have to look around and see.
To mount the shocks, use Tamiya's mounting hardware . With that, I think it's an easy fit, IIRC.
Rob
Rob Mincey is offline   Reply With Quote
Old 12-06-2004, 02:04 PM   #10653
raving-monkey's Avatar
Send a message via MSN to raving-monkey
someone else mentioned this to, but there is actually oil missing from the shock when i rebuilt them.
raving-monkey is offline   Reply With Quote
Old 12-06-2004, 02:21 PM   #10654
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Recently got an FK and would like to get any foam set-ups for an asphalt track. All the quick guys use 40shore fronts and 40shore rears and will also be using the same set of tires, so any help on some setups that might work for the car.
Another thing, What are the pros and cons of placing the batteries to a split position (one side is closer to the front)?
Regards,
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 12-06-2004, 02:28 PM   #10655
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
Default Xray Setup Sheet
Here's an Xray setup sheet for you guys to use...
Nrctc3 is offline   Reply With Quote
Old 12-06-2004, 02:34 PM   #10656
JDXray's Avatar
Send a message via AIM to JDXray
Regards,
If you have the one pair of batteries up front it would increase your steering and more grip in the front i think. Someone could double check me.
Jon
JDXray is offline   Reply With Quote
Old 12-06-2004, 03:29 PM   #10657
JBennett's Avatar
Send a message via AIM to JBennett
Post Gearing
Who knows some good gears i should get for my T1R.
I have a T1R with a 2.1 internal ratios with 64 pitch gears for a Stock motor?
Jason
JBennett is offline   Reply With Quote
Old 12-06-2004, 03:33 PM   #10658
JDXray's Avatar
Default Re: Gearing
Jason
try 120/128t there pretty good on the T1R. And your can try 24-28 pinions. The FDR would be around 7-9's.
Old 12-06-2004, 03:43 PM   #10659
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Jon
correct
dontfeelcold is offline   Reply With Quote
Old 12-06-2004, 04:06 PM   #10660
JBennett's Avatar
Does anyone have a good set up sheet for a T1R that would be good for outdoor racing with a Stock Motor?
Old 12-06-2004, 05:00 PM   #10661
Nrctc3's Avatar
white springs all around, 2* camber, 2 holes open, 3rd hole in front tower, 4th on rear, 2* toe-in, 1/2* toe-out.
Old 12-06-2004, 05:27 PM   #10662
Rob Mincey's Avatar
That's almost my outdoor setup exactly. I run 6 degree caster blocks, as most outdoor tracks seem to be more open and flowing where you'd need more on-power steering.
Rob
Old 12-06-2004, 05:29 PM   #10663
Nrctc3's Avatar
I run 3* blocks, havent really had time to experiment with others.
Old 12-06-2004, 05:45 PM   #10664
Michal101's Avatar
Originally posted by Scrad
My car is handling pretty good, but it hooks in the middle of the corners. (Rotates fast). How can I fix this without changing the handling in other areas?
Anybody???
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 12-06-2004, 05:47 PM   #10665
Nrctc3's Avatar
It would be great if you listed your setup. I run a spool & a light diff in the rear and havent had this problem.
