Xray T1
#7936
Originally posted by gido
How can it be done without the screw hitting the wheel?
Thanks again!
Thanks again!
#7937
Originally posted by etzkev
Oh, wow, thats wierd!
-Kevin
-Kevin
Robinsons, RWs, Xenons, etc. have the same hole patterns that are different from the Kimbroughs.
#7938
Originally posted by jag88
Can any of the EVO 'pilots' out there tell me their experiences with the ajustable center oneway ? Good, bad, no change ? Carpet or pavement. It seems that it would be a trick ajustment for fine tuning.
#7939
Originally posted by JDXray
or you could use a x-acto knife to cut the hole.
#7940
Precision RC spurs are very nice. The holes line up on that spur.
#7941
Neil, can you elaborate a little. I'm curious as to what you didn't like about it.
I remember a ways back that the HPI Pro 2 offered an ajustable center oneway as an option.
Thanks.
Thanks.
#7942
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Sands
That setup guide is a blinder man
#7943
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Set up tips
Does anyone have the address to Josh Cryl's site.....
#7944
#7945
Hey all,
I just got a quick question. After installing the Low Ratio Gears, and using the same Spur, I have to go up on the pinion teeth right?
Thanks,
Kevin
Thanks,
Kevin
#7946
Yea..if you want to smoke your motor.. but really the way to look at it is your ratio is now 1.77(??) so if your running say a 93 spur you would want to run a 23,that would put the final at 7.15..a good starting point for a stock motor,19 wind 21 or 22 and thats with a 93 spur.
#7947
Wait a second. That doesn't make sense at all. You are saying a 19 needs to be geared 21 or 22, and a stock needs to be geared around 23. 19's are always geared higher than stock motors!
Anyways, I'm not a newb and I can gear it, but I was just wondering what to expect. So, I am going to have to gear lower?
Oh, and yes, you are correct in that the ratio is 1.77.
Thanks,
Kevin
Thanks,
Kevin
#7949
Oh, ok. Thanks for the help Brian. I could have figued it out myself, but I felt kinda lazy. Didn't feel like doin' math or trying differen't pinions!
Thanks,
Kevin
Thanks,
Kevin
#7950
question?
i hav a foc kit whats the problem with this after i check the toe in in the rear its 1 deg. left and 2 deg. right check all the spacers its all der. do i hav to change the arm in the rear or the c hubs?
